53 Belair conv rust repair - Page 339 - Hot Rod Forum : Hotrodders Bulletin Board
  #5071 (permalink)
Old 03-24-2020, 03:55 PM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
I have been doing that for m any years, especially with broken bolts.
Caterpillar had a problem with the exhaust manifold studs snapping off over time from the expansion/contraction they experienced. Sometime in the early 90's they got the bright idea to replace the steel studs with stainless. My '92 had those studs when most of them snapped in about '97. I spent about $100 on special titanium drill bits to drill stainless and work them out with left hand bits and extractors. Took 2 DAYS to get 12 studs out and replaced !! The replacements were forged steel again and when they broke, I was in my new shop with the mig and built them up long enough to grab and the heat released the threads. Still took a day to do the job, but only a couple hours to get the studs out.
The Following User Says Thank You to Too Many Projects For This Useful Post:
John long (03-24-2020)
  #5072 (permalink)
Old 03-24-2020, 04:01 PM
MGK's Avatar
MGK MGK is offline
I hope your tetanus shot is up to date.
  #5073 (permalink)
Old 03-24-2020, 04:10 PM
What on earth are you talking about? This thing is a cream puff!
John
The Following 2 Users Say Thank You to John long For This Useful Post:
MARTINSR (03-24-2020), Too Many Projects (03-31-2020)
  #5074 (permalink)
Old 03-24-2020, 04:21 PM
MGK's Avatar
MGK MGK is offline
I've had to get 3 in the time I've been working on mine, glad the metal work is done. Still donate blood to car occasionally. My hide isn't as thick as it used to be.
The Following 2 Users Say Thank You to MGK For This Useful Post:
John long (03-24-2020), Too Many Projects (03-31-2020)
  #5075 (permalink)
Old 03-31-2020, 07:58 PM
Several things are happening on Precious.
Steve finished my installation of the park brake. I had installed a bell crank and cables to the crossmember and Steve mounted a park brake pedal and ran the front cable to the bell crank. That was a really cool surprise.
The heat/air unit came in and Steve has the engine brackets on and the condenser mounted. This is a major step forward.
I took my convertible top assembly to the sand blaster's today. They say a week and a half to do it. It's hard to believe but they estimated $80 bucks to blast it. We will see.
Today, I also found out the chrome plater that has my pieces was shut down by the government on the 23rd. The city doesn't think my chrome is essential. I have no idea when I will get my chrome back.
It is time to order the convertible hydraulics for the car also but my wallet is not wanting to open up.
John
123pugsy (04-01-2020), Too Many Projects (03-31-2020)
  #5076 (permalink)
Old 03-31-2020, 09:09 PM
Rip VW's Avatar
I will endevour to persevere
Last journal entry: This thread is officially Kaput as of 11/07/2017
John, A question for you? Isn't a 53 Chevy a 6 volt deal. How are you going to deal with a 6 volt pump in 12 volt electrical system? You going to use something like a volt a drop? Or do you have a 12 volt pump? Just kind of curious that's all.
  #5077 (permalink)
Old 03-31-2020, 09:47 PM
That is a good question Rip. They make the original pump in a 12v version for $239 and I have one out of a mid 60's Cadillac which needs to be rebuilt. They do make a rebuild kit for them though. I definitely will use a 12V pump. The truth is, the cylinders don't know what kind of pump is pushing them.
You can buy all new cylinders, pump, and hydraulic lines for about $600 bucks which is not what a "frugal" guy wants to do but I suspect it would be smart.
John
The Following User Says Thank You to John long For This Useful Post:
  #5078 (permalink)
Old 04-01-2020, 04:08 AM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Damn....you'll be waiting at least two to three months for that chrome....
  #5079 (permalink)
Old 04-01-2020, 06:36 AM
John
Rebuilding 67 year old cylinders and pump would, most likely, cost about that anyway. The big question is, are the components in the new kit rebuilt originals, or cheap, Chinese replacements ? If the "new" stuff is inferior aftermarket, I would have the originals rebuilt.
  #5080 (permalink)
Old 04-01-2020, 07:57 AM
Yup. And my alignment pins for the top are there. I may take soft hardware grade bolts and try to make temporary replacements.
My stuff is/was way beyond rebuilding. There are two companies that specialize in convertible parts. They advertise their parts are American made. For all I know both companies parts are coming out of the same plants. I just don't know. Hydro-E-lectric is one and has been around for years.
The Cadillac pump I have runs but slowly and sounds like it is laboring. I suspect it is pretty corroded inside. It very well could be cleaned and rebuilt if I decided to fool with it.
John
  #5081 (permalink)
Old 04-01-2020, 08:21 AM
Did a little research too and FL and CA are the hot spots for convertible parts. They all claim the cylinders are new USA made, but I don't see that claim on the pumps.
Sounds like new is the route you should take. Sticking with a well established, highly reputable company should be safe. Some offer 5 year warranty, where others are only 2-3.
John long (04-01-2020)
  #5082 (permalink)
Old 04-01-2020, 09:40 AM
Rip VW's Avatar
John,
Because I try to be frugal also, my choice would be to tear down the Caddy pump and rebuild it! It sounds like it has dry bushings in the motor. I have seen a lot of that with old electrical motors. They usually use bushings impregnated with oil and the oil get old and dries out and causes the shaft to bind. I have also seen motors with ball bearings do the same thing with grease when it dries out.
In the interest of frugality I would take the Caddy pump and tear it down and clean the stuffing out of it. it may not need much at all. If it turns out fu- barred then on to the next option. I might even consider a Bone yard pump. Find something as new as possible and use that.. Lots of options there..
  #5083 (permalink)
Old 04-01-2020, 06:41 PM
Agreed on checking the pump I have Rip.
I found cylinders for $118 each in California Mitch with free shipping.
Believe it or not guys, the sand blaster called today and said my top assembly is ready. A 24 hour turn around and he said I owed him $80 bucks. If it is good work, how could I ask for more?
I need to go get them tomorrow before they get locked down too.
Steve has the A/C evaporator assembly mounted in the dash but it is interfering with my converted OEM radio by about 1/2 inch. That is a disappointment but it is what it is. He also Epoxy primed the alternator and compressor brackets today.
I did misunderstand yesterday. The condenser is not mounted yet. I sure hope I left him room for it.
I hope everyone and their loved ones out there are safe, and healthy.
God bless.
John
The Following 6 Users Say Thank You to John long For This Useful Post:
123pugsy (04-01-2020), 496CHEVY3100 (04-02-2020), Gearhead Poppa (04-02-2020), idrivejunk (04-01-2020), Rip VW (04-02-2020), Too Many Projects (04-01-2020)
  #5084 (permalink)
Old 04-01-2020, 07:37 PM
123pugsy's Avatar
Wiki Edits: 29
It would be nice if you opened up the radio and found that the outside box could be trimmed back.
  #5085 (permalink)
Old 04-01-2020, 08:03 PM
Yep, saw that website this morning.
I don't remember if a new pump and lines are included in free shipping, but one would think so.
Apparently your blaster is slow on business too. If the parts are really clean, he might deserve a tip ...
rust repair blackchevy3de Body - Exterior 0 06-22-2010 06:15 PM
What to do for this rust repair? chevymike Body - Exterior 5 06-04-2010 05:49 AM
Rust repair help mydixie Body - Exterior 3 02-22-2006 07:07 PM
rust repair fennerford Body - Exterior 3 12-28-2004 04:30 PM
Rust Repair gguertin145 Body - Exterior 5 11-27-2003 07:02 AM
