55- on rotissery/rolls away - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2016, 03:20 PM
bsa_bob2's Avatar
Iam looking for a way to prevent this from doing so. I just got my 55 up on this roto..for lack of a better word. the wheels are 6" and roll super easy, Have you ever know of this problem ,i sure haven't . i need ideas that will stop this . BEFORE my kar runs over me . last line joke
6 wheels and has nylon centers and Rubber tires .You could push this roto anywhere with almost anything on it. BUT me!! it just wants to throw me on my arse. thanks for any clue to this few pics ..if you need more i 'll get more pics thanks for any tip or clues that will work. Bob s
Name:	rotissery finished 001.JPG
ID:	268657   Click image for larger version
Name:	rotissery finished 002.JPG
ID:	268665   Click image for larger version
Name:	55 rotissery problems 001.JPG
ID:	268673   Click image for larger version
Name:	55 rotissery problems 002.JPG
Old 01-17-2016, 04:09 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
There are made castors that size with a foot brake on them..Might need to spend a few of those nickels though..
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
bsa_bob2 (01-18-2016)
Old 01-17-2016, 04:21 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
I usually tie a rag around the wheel. That is to say- I jam a rag under the wheel a little and wrap it around, at the floor. Works pretty good when the casters have no brake.
The Following User Says Thank You to idrivejunk For This Useful Post:
bsa_bob2 (01-17-2016)
Old 01-17-2016, 06:47 PM
Maybe a couple of C-clamps tightened on the casters would work. Or cut out a wooden wedge that you can jam between the top of the caster wheel and the underside of the steel "fork" that the caster wheel fits into.
Old 01-17-2016, 10:11 PM
Fasto44's Avatar
Last journal entry: Old Shop Truck - '56 F-100
We use angle iron chocks on our race tire carts. We made them out of 1 1/2" L angle. They are three pieces welded into a "C" shape. Make the "C' long enough for the other two legs to capture the caster wheel. They work realy well and are easy to make.
The Following User Says Thank You to Fasto44 For This Useful Post:
Old 01-17-2016, 11:01 PM
Guest
Location: in the land of Trolls at least till the san andreas releases the big one
drill a hole in the side of the bracket that holds the wheel. weld a nut centered over that hole so it intersects the side of the tire rubber area..
cut a piece of sheet metal into a V shape...punch a hole for the axle to slide thru at the bottom of the V.. . put some ears or bend it so it won't rotate away from the angles of the wheel bracket... install this on the inside of the bracket.. if you weld a washer to the head of a bolt. now you can lightly tighten the bolt and depress the V shaped with wings sheet metal piece in to LIGHTLY apply drag to the wheels..
if you do the same thing but make an UPSIDE DOWN U shape that is tack welded in place.. you can tighten the wing nut headed bolt that is at 45 degrees to it does not effect clearance of the wheel rotating directly into the middle of the tread.. locking your caster wheels in place.. you would probably only need to do two of them .. but you could do 4...
Old 01-18-2016, 09:32 AM
bsa_bob2's Avatar
Thats agreat idea Wayne,,,,i'll be considering this idea...this afternoon
GOOD idea bob s ........thank you much Wayne
Old 01-18-2016, 09:39 AM
bsa_bob2's Avatar
Sam
Going to town today to check our H/F first .Nickles do get rare.Ihave had clamps on the wheels [plastic=- so that won't work well Wedges ......i would think that they would work their way out as you move around working on the body. and maybe not. Least i have ideas i didn't have befor this post BIG THANK YOU goes out to all you guys who expressed their ideas.Great forum for this Bob s
Old 01-18-2016, 11:18 AM
PHWOARchild's Avatar
Sam
Put them on 2 diagonal corners and it'll stay put.
Old 01-18-2016, 05:56 PM
bsa_bob2's Avatar
$17.00 for 2, not i when i have these great ways to do my own locks, all i could get was 4"......i have 5' wheels.Goin down thru these suggestions; tomorrow morning, see what hits me,for a way. thank you bob s
Old 01-19-2016, 07:02 AM
bsa_bob2's Avatar
Has anybody here ever tried 3/4" bolts thru and adjusting ..welded to the Rotissery legs Basically lifting the " this outfit" up a tad off the floor. Dong 3 legs would be quicker job. Whats your take on this idea, i think personally it could be a good way to go. AS i sat looking this "monsrtosity"on both ends of the 55. It dawned on me. bob s ..............whats your thoughts I'll wait awhile for feedback bob s
Old 01-19-2016, 10:50 AM
Guest
that is a great idea.... welding on some coupling nuts to the sides of the legs and using all thread.. as a crank down to stop the movement. might stick a nut about an inch up from the bottom end and an inch and a quarter of 3/4 heater hose.. so it has a rubber to the concrete stopper or a crutch stopper if you want to get fancy...
Old 01-19-2016, 11:08 AM
bsa_bob2's Avatar
Here is my final idea .Think it will work good. May help someone else. Easily done ...no nickles cheapo .Saves bucks for my project thanks again bob s
My cameras gettin old!!like me. hope you can see it. Basically i just tighten the hex head with a wrench.thinking bout welding a wing on it--of some sort.
ID:	269586   Click image for larger version
ID:	269594   Click image for larger version
Old 01-19-2016, 01:12 PM
bsa_bob2's Avatar
wants to tear into the rubber tire to much back to the drawing board
Old 01-19-2016, 02:15 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
rags will work as good as anything.
rolls but wont fire m/w Engine 3 05-25-2011 01:15 PM
S-10 to Rolls Royce graft wakemaker Suspension - Brakes - Steering 12 12-16-2010 10:59 AM
S-10 to Rolls Royce graft wakemaker Introduce Yourself 4 11-30-2010 07:32 AM
Mike Rolls Fitter Mike Introduce Yourself 3 01-14-2006 03:23 PM
Rolls Royce racecargurl Hotrodders' Lounge 9 01-15-2003 10:13 AM
