'57 BelAir hood alignment - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-31-2018, 09:29 PM
Originally Posted by KiwiStarChief View Post
Brian, unfortunately that didn't remedy the problem. The front bolt did move slightly in the slot when I lifted the hood up high, but the corner still sits up. I have taken the photo below of where the hinge mounts to the firewall as suggested.
Someone on another forum suggested that putting a shim under the bottom hinge firewall bolt will drop the corner down, as it alters the hinge geometry.
I had a go at this, but when I loosened both firewall bolts the weight of the hood wouldn't let me move the bottom of the hinge away from the firewall to insert a shim. I was working by myself, and don't have enough grunt, so was waiting on my son-in-law to come around to assist.
Yep, that is what you need to do, shim out at the lower bolt. If you loosen that bolt you can lift it like you are opening the hood? That' show you do it, push up on the hood standing in front of the car. If you can lift it there, just put a pole to hold it and then put your shim in.
  #17 (permalink)
Old 01-01-2019, 04:36 PM
KiwiStarChief's Avatar
Thanks for the advice Brian and John. I have done what you have suggested, including shimming out the lower hinge bolt, but it all has made almost no difference.
Apart from replacing the hinge (as the cog wheels may be out of alignment, somebody has suggested) which I would rather not do at this point, I'm left with slotting the hinge I think.
I will attempt this over the next few days, and advise back on the outcome.
Once again, I appreciate all your suggestions.
  #18 (permalink)
Old 01-01-2019, 05:27 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
However I just wonder if it would be easier to slot the bolt holes where it bolts to the firewall by the 3/8", and drop it that way.
If you can access your hinge-to-firewall bolts somehow, with the hood already closed and latched, you could loosen or remove them and see if that corner goes down. If it does, slot / shim it so it sits in the right spot when bolted tight. Looks like that may put the washer out over the edge of the hinge but I bet you can deal with that if it solves the problem.
Since the guy with the Chevy has similar drama, this could be an inherent issue present on lots of cars made then. But, the original poster says his bounces a little going down the road. If yours also can be pushed down once closed... sorry, men... worn hinges are a prime suspect. By the same token as the above suggestion, unhook the spring and see where she sits. If it lays down then, great. But if it can still bounce, thats hinge slop.
To the OP, just be careful when affecting latch closing. I have seen too many cases where a guy gets his hood closing "nice" and needs a hood, windshield, and roof the next week. A bit of effort will be required to close a properly adjusted setup, and any movement possible when closed (such as when side bumpers are left out) is a time bomb.
In a nutshell, do whatever is necessary at the firewall. You are probably compensating for hinge wear by doing so but no matter. Its old enough that modification might be required to make things work and fit right.
The top side mounting arrangement certainly is a circus on the Pontiac anyway.
Only other tip I can think of is to be sure the right front hood height bumper is making contact.
  #19 (permalink)
Old 01-01-2019, 06:56 PM
You could slot the hole in the front bolt on the hinge to hood easier and it WOULD bring the hood down.
In fact, it doesn't matter if the hinges are worn, it will still bring the hood down.
  #20 (permalink)
Old 01-01-2019, 07:38 PM
Is it possible that there is a bumper, cowl lacing, or other object interfering with the hood settling down?
John
57 belair front swap mdrodder58 Suspension - Brakes - Steering 2 05-29-2006 10:25 PM
Wiring diagram 57 Chev Belair generator to alternator shoebox5657 Electrical 3 10-09-2005 04:58 AM
My 57 BelAir will geting a 4 Link Elevinpointsixtoone Suspension - Brakes - Steering 7 12-19-2004 11:53 PM
57 Belair 2 door post 57 heaven Engine 5 09-14-2003 08:54 AM
LOOKING FOR 55 - 57 Belair or 210 Door Hinges BATMAN Body - Exterior 0 03-20-2003 07:14 PM
