'57 BelAir hood alignment - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2018, 07:35 PM
cdoc164's Avatar
My hood is aligned front/aft and left/right and sits flush with the passenger side fender and cowl, but sits slightly high on the drivers side fender. Also it moves up and down slightly when driving (on the drivers side). I placed washers above the bushings in the latch which tightened it to where it is now but if I add any more the latch doesn't release properly. Before adding the washers the hood sat high along both fenders. Any advice for proper hood alignment?
Old 12-30-2018, 08:03 PM
“Basics of Basics” Body panel alignment
By Brian Martin
Nothing adds to “detail” on a car more than nice fitting panels. If the car is a light color it is even more important. Those “black lines” that are the gaps between panels really look bad if they are not a consistent width. While using this guide and aligning your panels be sure that you open and close the moving ones very carefully after a change. You can loose the gap fast which will allow the panels to hit, so be careful.
I have to start with this very important point. ALWAYS have the car sitting on it’s wheels or at the very least the weight of the car should be on the axles. That being if you want it on jack stands to raise the car up and give you more access to the bolts and such, place the stands under the control arms as and rear axle. They should be out as far as possible towards the wheels. This can still cause problems on the front. Even in a little from where the tire actually holds the car up can change the amount of pressure being exerted on the car’s body. A car can be twisted or bent more than you can imagine up on jack stands when the stands are set on the frame allowing the weight to hang off the ends. This is VERY, VERY important. Of course this goes for anytime a panel is being fit, either welded or bolted on.
Hood alignment: Let’s start with raising and lowering the rear of the hood. If the car you are working on has a hinge that sits on top of the cowl, your only options are to shim or bend the hinge. Bending the hinge slightly is one way to move it. If you need to come up in the rear you can put a small block of wood or other item on the hinge, to bend it. When you close the hood down (NOT ALL THE WAY) it will get in the way of the hood closing and bend the rear or the hinge up. If you need to bend it down, the only option may be to remove it and bend it a little. You can also shim the bolts between the hood and the hinge, more on this later.
If you have a hood where the hinge mounts on the side of the fender or the side of the cowl like with an older car or truck, you want to "rotate" the hinge on the fender. Just pushing the hinge up and down will give you very little movement on the top of the hood.
This is the strange little trick that you have to remember, if you raise the back of the hood on the hinge or raise the back of the hinge on the fender the hood will go up. If you raise the "front" of the back of the hood ON THE HINGE or the hinge to the fender it will go down. What you have to remember is you are working with a pivot point in the hinge, not a stationary part.
If you loosen the FRONT bolt on the hood (where it bolts to the hinge) and put a shim, or washer between the hood and hinge, this will LOWER the hood on that side. If you put that same washer under the rear bolt it will RAISE the rear of the hood on that side.
So, if you loosen the bolts from the hinge to fender and close the hood, the hinge will rotate on down in the front right? This will raise the REAR of the hood like putting a shim in the back bolt between the hinge and hood!
What you need to do to lower the back the hood is to loosen the bolts (only slightly) and PUSH UP on the front of the hood. This rotates the hinges back, thus raising the front of the hinge and lowering the hood in the back.
If the hinges are warn out it won’t change how high the hood sits when the wear, not by more than a fraction of an inch. And I have never seen a car with these style hinges that you couldn't put the hood a half inch LOWER than the fenders if you wanted to. The adjustment is HUGE on these cars. That is one of the things that is easy to do on them is align panels.
I recommend you remove the striker or latch from the hood so that you can move it up and down without worrying about the latch grabbing the hood. After you have aligned the hood, take a piece of dumb-dumb or clay or something similar and put it on the latch. This way you can see exactly where it hits when you do install the latch. You bring the hood down till you just tap this dumb-dumb but DON'T LATCH IT. Just so the hood makes an indentation in the clay/dumb-dumb. This tells you where you have to move the latch.
I do this at work everyday, by myself so if you can't get help this is the trick. Always leave one bolt on the hinge tight. If you want to rotate it back, leave the front bolt tight. If you want to rotate it forward, leave the rear bolt tight. When you move the hood forward or back on the hinge, leave the bolts snug enough that you have to tap on the edge of the hood to get it to move. Or if it needs to go back, leave the bolts a little snug, and wiggle the hood up and down and the weight of the hood will make it slide down. Remember it only needs a 1/16" or so to make a 3/16" or more change at the front. To pull the hood forward on the hinge loosen them so they are still a little snug so you have to pull up on the back of the hood to make it slide that little bit. If you loosen it up so it moves anywhere you want it, YOU WILL NEVER KNOW HOW MUCH YOU MOVED IT AND YOU WILL MOVE IT TOO MUCH, GUARANTEED.
Get the hood laying flat first, then move the hood forward or back on each side to make the hood fit the hole between the fenders. If the gap is large on the front right and small on the front left, then the hood needs to me moved back on the right side. As you move the hood back on a side it will close up the gap in the front of that side and open it at the rear of that side.
You may need to move fenders too. Just do each change slowly, move it VERY LITTLE. Look at the bolt and washer as you move the panel, you will see where the washer used to be, the amount is much easier to control if you watch the washer movement.
If you need to move the hood up or down at the front, you have a few ways to do it. First, on each side there are the “bumpers”. The hood bumpers are located at each front corner and look like a bolt with a rubber pad on top. Just unlock the jam nut and raise or lower the “bolt” so it holds the hood at the height you need to match the fender. You may find that the hood won’t go low enough even with the bumper down far enough. The latch may not be down far enough. When you close the hood, you shouldn’t be able to pull up on the hood or push it down. The latch should be tight enough to hold it against the bumpers tight, but not too tight. If you have to apply too much force to open the hood or it opens with a loud POP, the latch is probably too tight. If it is at the right height but you can lift it up some, then the latch needs to be moved down.
Doors: If the doors are off the car, bolt the hinges to the door and the cowl in the middle of the movement allowed. Let’s face it, it “shouldn’t” be too far off the center of holes. If the doors are on or if after putting them on things are way out of whack, raise the door up on the hinges as far as it will go while still staying about the right height. You always want to start high, it is much easier to come down than go up. Besides this is the ONLY time you will loosen all the bolts on the door. I don’t mean ALL the bolts, leave the hinge to cowl (or center post on a four door) tight. Only loosen the door to hinge bolts. Unless it is WAY down then you may need to move the hinges up too. But do one at a time, both door to hinge or both hinge to cowl/center post.
While moving the hinges aligning the door NEVER loosen all the bolts on the hinge, NEVER. Loosen all but one, just till it is still a little looser than “snug”. Leave that last on just a little snug. Let’s say the door fits well but is a little too far rearward. NEVER loosen top and bottom hinges and move it forward. Loosen the top hinge to cowl/center post as described above and lift the rear of the door, a LITTLE. This will push the upper hinge forward. Now TIGHTEN that one bolt that was left snug. Do the same on the lower hinge, pushing down, but remember the weight of the door is helping, so little push is needed. Many times no pushing at all, just the weight of the door will do.
If the door fits well but is out at the top or the bottom, again, loosen ONE hinge to DOOR in the manner described and push it out or in. If it is out or in at the top rear for instance, move the bottom front in the opposite direction. This will pivot the door on the striker, and move the rear top where you want. Moving the bottom rear takes moving the top front of course.
You may need to twist the door. If the front fits well and rear is out at the top (or bottom, just reverse) you can put a block of wood at the rear of the door at the top lets say and push in on the bottom to twist the door. Some will take a LOT of force to bend, and be VERY careful not to let your fingers hang around the outside of the door edge!! I lost a finger nail doing this on a ’69 Shelby GT500 convertible once (remember it well) when the block of wood fell out with all my weight on the door while twisting!!
Tip: If you are hanging the door and you have access to the hinges (either through the wheel well with the skirt off or if the fender it’s self is off) you can simply hold the door up to the opening and push the latch shut. Then put the bolts in the hinge. I can often install doors all by my self in this way.
Deck lid: The trunk lid is pretty much like the hood but the hinges don’t move at all on the body (usually). So shimming and twisting are a few of your only options beyond the movement in the slotted holes on the hinge. Bending the hinge or pushing up or down on the sides of the quarters, front or rear panel are the others. These should be done ONLY after all other things are tried.
Fenders: Most of the tips for doors and the hood work here, with a little twist or two. Start with fitting the rear top of the fender. I like to put all the bolts in, loose. Not falling out loose, just so the fender would easily move. Close the door, and with the hood open adjust the gap at the top of the rear of the fender to door. After you tighten other bolts this cannot be modified so, do it first. Tighten the bolt under the hood closest to the door to secure the position. You may need to shim a bolt at the rear of the fender to the cowl, to move the fender forward or back. After you have that bolt tight and the gap is to your liking open the door and tighten the rear fender bolt that is at the top of the fender in the door jamb. Now do the bottom bolt, with the door closed, adjust your gap. You may need to wedge a flat blade screwdriver or body spoon to “force” the fender forward to get the desired gap. Or just the opposite, use a 2x4 or something similar off the front tire to force the fender back to get the gap. This is one of the hard spots to get nice because you have to get both the gap and the in and out of the fender to door at the same time with the same bolt. Some cars have two bolts that are far enough apart to get the gap and tighten the front bolt and then pull the fender in or out and tighten the rear bolt to get the flush fit of the panels.
General tips: Bending a panel or adjacent panel is sometimes required. You can get this done in a number of ways, one is to use a block of wood. Let’s say that along the edge of the hood there is a spot that is high. Well you can’t adjust it down, the front and the rear are perfect. So you can lay a block of wood on the spot, right at the edge where it is strong. Using a big hammer (the bigger the better, trying to make a small hammer do the job can cause a lot of damage) hold the block and strike it nice and solid. Then check the results, you may need many strikes to do it. In doing this you may want to support the hood at the front with a block of wood under the hood. This way the hood is up off the fender and it will bend easier because of the solid rest it has. You can also put the block under the edge of the hood at a low spot and with steady pressure bend it down at a point if you need it.
If you are working with very tight tolerances, you can actually grind the edge of a panel or jamb to get an extra fraction of an inch. Be VERY careful and using a fine disk like 80 or 120 take a LITTLE off. You don’t want to grind the metal thin of course but a LITTLE can make a big difference when you are fighting for fractions. Now, you really won’t be cutting too much metal, you are really just cleaning off ALL the primer and paint there. Then when you prime it, don’t put a lot or sand it thin so there will be very little on the edge.
You may want to paint the hinge with a little contrasting paint. Do it with the hinge bolted on, right over the bolts. This way you can see easier how much you have moved it.
These directions are for doors where the hinge bolts flat to the side of the cowl and then flat to the front of the door. There are of course many ways the hinges can be mounted on cars. If yours are different than you need to use the “concepts” that I have described here. If for instance you have a 1950 Chevy pickup. The hinge bolts flat to the back of the cowl but will work the same way. The door hinge bolts flat to the side of the door. In this case you do just the opposite as I earlier described. You would loosen the hinge to cowl bolts to move the door in and out and the hinge to door bolts to move it back or forward. If you find that your car has a design that hasn’t been addressed, take a good hard look at your hinge arrangement. If the door is open, close it enough while you can still see the hinges and imagine what direction will it go if you loosen a particular set of bolts. Get an idea of how you can move it, then start the alignment process.
These are just ideas that I have used over the years and some may work for you some won’t, but it is a start. Above all, have fun!
Old 12-30-2018, 08:15 PM
cdoc164's Avatar
Thank you MARTINSB! Looks like a wealth of information!
Old 12-31-2018, 12:21 AM
After you have walked through with that, post some photos in the body forum https://www.hotrodders.com/forum/body-exterior/ and we can walk you through it if you need more help.
Is it high all the way back to the cowl?
Old 12-31-2018, 07:30 AM
cdoc164's Avatar
Yes, and after looking closer this morning it is also higher at the cowl on the same (driver's) side.
Old 12-31-2018, 09:51 AM
Brian, there was a drawing posted somewhere that did an excellent job of showing how the hood hinges moved the pivot point way back behind the hood.
Do you remember where it was? It did a great job of helping to visuallize your explaination and instructions. Understanding why raising the hood to adjust the hinges will lower the hood's position is half the battle.
John
Old 12-31-2018, 10:02 AM
Unfortunately, the '57 hinge bolts to the front of the firewall and you can't really "Rotate" it very easily. You could shim the upper bolts between the hinge and the firewall. But I think it would be much easier to shim up the hood at the front of the hinge where it bolts to the hood. Put shims between the hinge and the hood on the FRONT bolt closest to the front of the car. Shimming up the hood there lowers it because the hinge will then go down further while still bolted to the hood.
The Following User Says Thank You to MARTINSR For This Useful Post:
John long (12-31-2018)
Old 12-31-2018, 01:46 PM
Yupper. It always sounds backward until you understand how it effects the hinge. My deck lid needed shimmed for the same reason.
I know this thread will not only help cdoc164 but others who read it.
John
The Following 2 Users Say Thank You to John long For This Useful Post:
cdoc164 (12-31-2018), MARTINSR (12-31-2018)
Old 12-31-2018, 01:50 PM
Yep, it is a DAMN HARD thing to get your head around! I have experienced techs look at me like I have told them to bend the steel with their mind when I say to "shim the hood down." LOL
And then I do it in front of them and their head explodes, no kidding, you have to wipe up the blood after.
The Following 2 Users Say Thank You to MARTINSR For This Useful Post:
cdoc164 (12-31-2018), John long (12-31-2018)
Old 12-31-2018, 02:46 PM
cdoc164's Avatar
Thank you. I will try that and let you know what happens. I appreciate the advise.
Old 12-31-2018, 06:03 PM
KiwiStarChief's Avatar
Hi Brian, I don't like to hijack other's threads, but this was so relevant to my own issue, I thought once won't hurt. I got quite excited when I read your solution, as the left rear corner of the hood on my '57 Poncho sits up about 3/8".
However, when I looked at how the hood was bolted to the hinge, it doesn't bolt to the underside of the hood, but to the side front and rear, with one bolt at the top.
Just looking for some confirmation to my thoughts, but if I adjusted the front side bolt up in it's slot (there is some latitude for movement here), and shimmed the top bolt the same amount, would it achieve what you are recommending?
Any advice or assistance would be greatly appreciated.
Old 12-31-2018, 06:40 PM
WOW, that is an odd baby, holy crap. OK, if you could get a better picture showing me how it attaches to the firewall or fender that could help. If the hinge bolts against the firewall you will have to do it at the hood. Ok, you would loosen the middle bolt on the hood get it out away from the hinge a ways, just to get it out of the way. You could remove it completely but if you loosen it up so it's away from the hinge, that's all you need. Then loosen the one closest to the front of the car a little and push up on the hood as if you are opening it further, up from the front. See if it moves at that front bolt, it looks like there is a slotted hole with room under it. Push the hood up, move that a little then snug the bolt up and see how it fits. Once you get it done and tighten it up tight the middle one may just tighten up as it won't be that far away. Or you can put a thin shim or washer under it.
But that I believe would get it done for you. Just don't loosen the rear one at all, you don't want it moving forward or back or something.
Old 12-31-2018, 08:32 PM
Brian, unfortunately that didn't remedy the problem. The front bolt did move slightly in the slot when I lifted the hood up high, but the corner still sits up. I have taken the photo below of where the hinge mounts to the firewall as suggested.
Someone on another forum suggested that putting a shim under the bottom hinge firewall bolt will drop the corner down, as it alters the hinge geometry.
I had a go at this, but when I loosened both firewall bolts the weight of the hood wouldn't let me move the bottom of the hinge away from the firewall to insert a shim. I was working by myself, and don't have enough grunt, so was waiting on my son-in-law to come around to assist.
Old 12-31-2018, 08:54 PM
However I just wonder if it would be easier to slot the bolt holes where it bolts to the firewall by the 3/8", and drop it that way.
Old 12-31-2018, 09:03 PM
If the front bolt has been adjusted as far as it can go, you can leave it snug and move the rear bolt in the opposit direction. Also, the advice to shim the hinge at the firewall will work.
A little patience should get you there.
Your goal is to adjust the front of your hinge so it has to travel further to close.
John
57 belair front swap mdrodder58 Suspension - Brakes - Steering 2 05-29-2006 10:25 PM
Wiring diagram 57 Chev Belair generator to alternator shoebox5657 Electrical 3 10-09-2005 04:58 AM
My 57 BelAir will geting a 4 Link Elevinpointsixtoone Suspension - Brakes - Steering 7 12-19-2004 11:53 PM
57 Belair 2 door post 57 heaven Engine 5 09-14-2003 08:54 AM
LOOKING FOR 55 - 57 Belair or 210 Door Hinges BATMAN Body - Exterior 0 03-20-2003 07:14 PM
