'65-289 SBF distributor question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2013, 01:14 AM
I would like to do away with the MSD 6A box & coil. I've got leads on several 600-650CFM carb, but that still seems like too much carb for the stock 289.
Since I'm also not familiar with the MSD stuff.....Q: can I get rid of the box & coil & still use the distributor alone?
I'll definitely appreciate as many opinions as I can get.
Last edited by LATECH; 09-28-2013 at 07:01 AM. Reason: duplicate post in old thread and electrical question
Old 09-28-2013, 06:55 AM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
If the coil is points you can easily run the distributor without the MSD box.
If you have a duraspark distributor with magnetic pickup , you want to run the MSD with it. It is a better system.
Moving to electrical forum
Fact is stranger than Fiction
Old 09-28-2013, 11:00 AM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
If the secondaries are vacuum-operated, it's difficult to over-carb a motor. That's the beauty of a Rochester Quadrajet, tiny little primary bores and venturis for good mixing/fuel mileage and huge secondaries for power. If the motor hasn't sufficient vacuum to pull the secondarys open, then the motor will just run on the primaries the rest of its life. No harm, no foul.
Old 09-28-2013, 01:00 PM
JeffB's Avatar
Why would you want to "get rid" of the MSD box and coil? Even with a stock 289 this would improve your fuel economy over a stock unit, the 600 CFM Holley has been used on the 289 for years second only to the Autolite 4100 that Ford used however there is a new star which combines the best of both with some upgrades:http://www.summitracing.com/parts/su...00vs/overview/ also users have reported smoother running and 2-3 more MPG.
SBF Procomp Distributor Advance Kit zildjian4life218 Engine 0 06-17-2013 08:48 AM
HEI Distributor on a 289 V8 Ronald J Berry Sr Engine 3 08-25-2008 04:56 PM
HEI Distributor on a 289 V8 Ronald J Berry Sr Engine 2 08-19-2008 05:39 AM
289 distributor single to dual vac ? StangIN65 Engine 2 03-23-2007 02:54 PM
sbf distributor nicowarrenrogers Engine 1 04-12-2005 10:18 PM
