67 camaro inline 6 cyl. engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2006, 07:05 PM
Hi guys!!! I am ready to startup my fresh engine and want to know if all the parts are properly matched: 266 cid 6 cyl. engine, compresssion ratio: 10,75:1, mecanical cam and lifters, 238/242 deg. @ 0,050 , .525/.532 lift crower cam (# 3311 ) roller rocker arms 1,75 from crower, cast iron cyl.head fully port and polish with 2,02 int and 1,60 ex , clifford 4 bbl alum. int. manifold, hooker super compet.header 1 5/8" with dual 2 1/2" pipes.Holley race carb. 650 cfm runing with 95 octane super gas. All the ignition system are from MSD.Can i have any help about horsepower and torque of this combo and this car is for street/strip use, equiped with 4 speed manual tranny and posi trac rear end with 4,10:1 gears, 26" soft street radial tires, high performance clucht kit and strip front/rear susp. The car weight is 2730 pounds ready to race! All the combo above sounds matched or can i improve or change some system of this car? Many thanks in advance for any help !!!
Old 07-26-2006, 09:20 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
HP / TQ somewhere between 200 - 250 on both.
Question...isn't that engine like a 3.3" bore? If so, you may run into issues as your valves will take up 3.62" of room.
If I'm wrong, please correct me...I am thinking off the top of my head.
Other than that, the combo looks ok to me.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
4 Cyl 85 Camaro sixfiend Transmission - Rearend 14 06-23-2005 12:16 PM
Suggestions? 67 Camaro needs balance of power/mpg. MadJester Engine 24 12-13-2004 07:52 AM
'36 P/U, 69 Camaro subrame engine help!!! Apathy93Z Engine 1 12-08-2004 07:54 AM
removing camaro engine by removing sub-frame bullheimer General Rodding Tech 7 04-23-2004 03:46 PM
