67 Chevelle owner - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2018, 01:06 AM
67 Chevelle owner
Hi: I am a 67 Chevelle owner and have a non stock Chevy SB motor. Can anyone decipher the code found on the passenger side front of the block? The code is K0806CKR. I think it's a 350. There is also a code 722100581 above the first code. Thanks so much.
Old 08-31-2018, 01:45 AM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Could be either.....
1973 350 350TH trans, California, Nova
1977 350 automatic transmission, engine code LM1, Nova
Old 08-31-2018, 12:25 PM
ogre's Avatar
the 'Duracell Project'
aka low hp era, had a 74 350 in my 58 that was rated 140 hp
i like that era chevelle, got pics???
Old 09-01-2018, 11:52 AM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
To get anymore specific, you need the casting number off the back of the block, on the left side and the casting date on the right rear.
The '77 engine was used in all platforms, A, B, F and X, so determining it's exact source would depend on the partial vin.
Doubtful it matters after all these years, as the internals and heads could be from anything. Pull a valve cover and get the casting number and date on the head and that may shed some light on if it is still original.
Old 09-01-2018, 11:57 AM
Thanks
I need a year for the engine only to satisfy a requirement for acquiring Collector Plate status. I've had other threads tell me it's a 69 block, 72 block, 77 block. I will check the rear of the engine for the number.
Old 09-01-2018, 12:11 PM
In MN, anything over 20 years old can be registered in a collector program. Either year you use should easily qualify in most states.
Old 09-02-2018, 08:24 AM
the #s K0806CKR decode as K= St Catharines assy plant, 0806= Aug 06 and the CKR as 1977 350 Nova auto trans 170 hp 4 barrel, there is also another CKR code that says 1973 350 Nova California, if you are looking for it to be at least 20 years old either one will certainly fall in that category
350, chevelle, chevy, code
Will a 69 Chevelle rearend fit my '67 Chevelle lt1_performance Transmission - Rearend 2 04-26-2008 11:10 PM
'67 Chevelle SS owner rodster100 Interior 5 04-11-2008 06:50 PM
67 chevelle 12 bolt fit in 70 chevelle? 70chevelle327 Transmission - Rearend 11 09-11-2006 08:52 AM
67 Chevelle Owner wolffie327 Introduce Yourself 2 12-28-2005 01:29 AM
New Chevelle Owner projectjohn Introduce Yourself 2 09-08-2005 07:53 PM
