67 Chevelle trunk - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2018, 03:12 PM
Luiz's Avatar
ChevyNut
67 Chevelle trunk
I'm removing the rusted floor of my 67 Chevelle. I'm going to instal the 3 section floor pan and the trunk drop offs. Should I weld the drop offs first?
Thanks,
Luiz
Old 07-01-2018, 08:03 PM
I am thinking you may want to post this on a good Chevelle site. Chevelle Tech - Powered by vBulletin
But basically you are on the right path I believe. I haven't installed one in pieces like that but I am thinking to get the center in over the top of the edges of the side ones would be the way to go.
However, many late model cars have those side pieces and they are installed over the top, so it could go either way.
Trial fit them set them in there even hold them with screws and test fit to be sure each one will come out and in so you don't get trapped with one welded in that you can't get another in, that would be a disaster so trial fit them.
Old 07-01-2018, 08:35 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Thanks,
Luiz
Yes. When I replaced the trunk floor in my 64 , the edges laid on top of the drop sections. There is a welt or relief in the top edge of the drops where the trunk floor lays on.As Martin Sr. suggested (and I did mine the same way) was to trial fit them and use a screw or two to hold them until you weld them down, just in case you need to make a few adjustments
My drops were fine, just the floor was rusty from a bad rear window seal leaking in. When I removed the rusty floor, the drops were obviously the next panel in line for disassembly - reassembly .
Fact is stranger than Fiction
Old 07-01-2018, 08:48 PM
Luiz's Avatar
ChevyNut
Thanks guys. Drop offs first. I bought a bunch of Clecos and they'll helpful for test fitting. The work is intensive with millions of spot welds to take care of.
Old 07-01-2018, 11:02 PM
Here is a basics on removing welded on panels.
https://www.hotrodders.com/forum/bas...ls-222549.html
And here is a little tip that should work out well for you too.
“Basics of Basic” Floor welding tip
By Brian Martin
This tip isn’t only for welding in floors, it can be used anytime. But it works the best when plug welding a thin sheet metal to a thicker brace, frame or whatever. Welding trunk floors into late model cars that have been rear-ended is common practice these days. Just a light hit on the rear of most late model cars will result in a badly crumpled floor and a frame rail or two needing to be replaced. After welding in many of these cars and always having a problem with keeping the floor nice and flat against the rails while welding, I came up with this trick that really works well for me.
I used to lay the floor and align it, then mark the underside around the edges of the cross members and rails with a sharpie. Remove the floor and punch all the holes around the edges of that line I made so I could plug weld the floor to in. I have some real nice punches with a long reach and I would drill the ones I couldn’t reach. This required cleaning up the back of the holes of burs and spraying some weld thru primer and what not, a lot of prep work. But I thought I was slicker than snot doing it this way, the thing sat back in there with a row of holes all the way around right in the right place and it really looked good. Until I started welding, no matter how nice I could do a plug weld, on these floors the darn thing would always come up a little around the holes as I welded and it looked like crap once done.
The solution is not only produces a better end product, but it is much easier. What I now do is to align the floor into place. I will hold the floor in with a sheet metal screw here and there just as before (later welding the hole up) but now I put them where ever I can draw a straight line from screw to screw or at least be able to know exactly where the rail or cross member is beneath the floor. I then mark it ON TOP of the floor where the holes need to be to plug weld it in. So, I have a nice floor pan with no ecoat removed, no grinding, no drilling, just a nice new pan sitting there on top of the rails. The rails by the way were cleaned with a Maroon Roloc surface-conditioning disc and a weld thru primer was applied.
I now drill a few holes thru the floor pan and a little into the rail. I use a killer spot weld drill I get from our fastener supplier (Winzer). They cut a shallow hole so I don’t cut thru the rail, but they have a pilot tip that is like an 1/8” drill to keep it where I want it as it starts. And they drill VERY fast. They are 8mm (about 5/16”) in diameter.
Soooooo, these few holes are now drilled, I have perfectly clean metal in the rail to weld to, the metal is a little thinned by the drill so I can get good penetration with a nice fast, hot weld! I weld these welds very hot and fast leaving a super clean flat weld on the top side. PLUS, the weld is so hot and fast that the surrounding floor pan doesn’t lift up from the heat as it did before. After a few welds, I drill a few more holes and weld them up, and on and on until it is done, skipping around side to side and even walking away and doing something else now and then to let it cool off.
I use this same method on radiator supports to the frame, when ever I am welding a thin metal to a thicker one. It produces a cleaner plug weld than anything I have ever tried when welding a thin metal to a thicker one. Plus, less corrosion protection is burnt off.
The Following User Says Thank You to MARTINSR For This Useful Post:
Gearhead Poppa (07-02-2018)
Old 07-02-2018, 07:05 AM
Luiz's Avatar
ChevyNut
By Brian Martin
Thank you for the precious information!
The Following User Says Thank You to Luiz For This Useful Post:
MARTINSR (07-02-2018)
Want to smooth the Trunk lid, but how to have a remote trunk latch?? shopman1 Body - Exterior 3 05-22-2014 09:47 PM
Will a 69 Chevelle rearend fit my '67 Chevelle lt1_performance Transmission - Rearend 2 04-26-2008 11:10 PM
67 chevelle 12 bolt fit in 70 chevelle? 70chevelle327 Transmission - Rearend 11 09-11-2006 08:52 AM
67 Chevelle trunk extensions IROC100 Body - Exterior 11 01-22-2005 03:11 PM
'67 Biscayne trunk mat MI2600 Interior 0 10-21-2003 08:32 PM
