67 impala strut rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2018, 09:08 AM
changing control arms, center link, tie riods, is the strut rod a support or alignment rod
Old 08-12-2018, 10:23 AM
Both, It keeps the lower a arm from moving front to rear. It also is used to adjust the caster when doing an alignment.
Old 08-14-2018, 10:45 AM
PHWOARchild's Avatar
Years back I would use new ones from the Chevy dealer rather than screw around with the old ones on a front end job. No idea if they are available. But these came with the nuts, washers and bushings. Before I took them out I would measure up one side and make both of the new ones the same length. This is from one of the small holes at the end to the back of the adjustment nut.
Then I got smarter on '65 to '70 Impalas. I would add maybe 1/4" of shims on the upper control arms. These never had shims. If I had a caster pull, I could jockey the shims around on the arms and not have to put the car back up on the rack. Once you touch the strut rods, you have to do the tow again.
Adjustable Strut Rods Molon Labe Suspension - Brakes - Steering 7 06-14-2018 07:24 AM
How do I replace strut rod bushings?? HotRodMan Suspension - Brakes - Steering 2 07-06-2011 05:29 PM
No Bind Strut Rods 42CHEVCOUPE Suspension - Brakes - Steering 1 01-12-2008 01:50 PM
Strut rod??? arborlis Suspension - Brakes - Steering 13 03-18-2003 09:08 PM
'62 Nova to late F-body strut conversion Jones Suspension - Brakes - Steering 1 10-02-2001 10:55 AM
