67 Le Mans...rust INSIDE deck lip and hood - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2014, 02:27 PM
So im working on my bros 67 Le Mans. His deck lid is rusting from the inside out, but it is not rusted through, it is just showing up like on the trunk side. The hood the same thing, like under the hood surface and between the hood and the support structure i guess you would call it.
how can i neutralize the rust, and spray some epoxy or por-15 style of product. its hard to get to. i know Eastwood has this can with a hose on it so you can spray inside chassis and such.
any primer can or product similar to that? or with Cheapwood work? lol
Old 05-18-2014, 02:40 PM
Cars, Trucks, Boats
. LOL! Eastwood is far from "cheapwood"...
. Rustoleum makes a rust converter available at most auto parts stores/WalMarts... Permatex used to, may have been bought out by Rustoleum...
. Scrape/remove as much loose/surface rust and loose paint as you can get to... prolly have to remove hood and trunk to manipulate them around... vacuum rust/paint away... spray a good soaking coat of rust converter in... repeat... with part in position so that it runs down into rusted area... let dry at least 24 hours in a dry, low humidity environment... then coat with a rust inhibiting primer... couple/three coats... then paint... the 3 different types of coatings work together to prevent any further moisture ever getting in again...
Old 05-18-2014, 02:47 PM
well ive heard nothing but bad things about their products, but thats something else.
will there is no scaly rust. its all surface rust. and i already have 2 gallons of SPI exopy ready to roll once im ready. but saying like the inside of the deck lid and hood. to where i cant get sand paper into, and i dont know if i should sandblast inside it cuz then i would have trouble getting all the media out. ill get pictures later on i had a brain fart and forgot to take them.
what about like some evaporust or rustover like product?
the real problem is accessing it, unless i skin it which im 100 percent trying to avoid. im already doing a damn roof replacement cuz it was a vinyl top
Old 05-18-2014, 06:50 PM
anyone have any idea which way would be best? or what method to go with? besides acid dip...
thank in advance
Old 05-18-2014, 07:38 PM
What ever you do don't blast it, or wire wheel it, either method will warp the outer skin. Your best bet is hand sanding the best you can, or chemical dipping in the big stripping tanks cleans the rust really good. Not really many options for you.
Rust inside the B pillar mustangsal Body - Exterior 8 03-02-2012 08:42 AM
Surface rust inside Engine Hood support off2wildblue Body - Exterior 3 05-09-2009 02:32 PM
Stopping rust from the inside. Sagacious Body - Exterior 12 12-03-2006 05:41 PM
fender lip rust repair blackjackbender Body - Exterior 10 03-24-2006 01:04 PM
removing rust on the inside of frames mj_lover Body - Exterior 14 07-24-2005 12:22 AM
