671 blower Carburetors leaking out linkage ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2018, 06:04 AM
Last journal entry: 51 chopped shoebox bbc
okay started my 671 blower sbc i am running two 850 demon carbs
i know little big but that's what i have, fuel pump is holley black
fuel pump regulator is set at 8psi front carb gauge reads 7 psi
rear carb reads 6 psi the problem is both carburetor are leaking
out of linkage back carb started first then the front carb
regulator is a mallory with return 4/12 psi
car was running good before but now started to leak
Old 08-27-2018, 09:10 AM
vinniekq2's Avatar
you can replace or rebuild the baseplate shafts easy. 850 cfm sounds like a perfect size carb(S).
Old 08-27-2018, 02:53 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Demon recommends between 5 and 6 PSI fuel pressure at idle. As Vinnie suggested, rebuild the base plates and then drop the fuel pressure to 5 psi. More pressure will not make more power with a carburetor. What it will do is to overpower the needle and seat assembly in the bowl and allow the fuel pump to blow raw fuel into the intake manifold, creating a tuning nightmare that will not be fixed until you lower the fuel pressure.
Old 08-27-2018, 08:16 PM
36 sedan's Avatar
Try lowering the pressure (5psi max) and re-adjusting the floats. I've had high fuel pressure flood my carbs with the excess fuel coming out around the throttle shafts. Lowering the pressure and re-adjusting the floats was the fix.
The Following User Says Thank You to 36 sedan For This Useful Post:
techinspector1 (08-27-2018)
350 valve covers leaking and leaking and leaking 85cjsm350 Engine 13 04-17-2016 07:35 PM
Are Zinc carburetors on there way out? eric32 Engine 5 03-15-2010 11:01 AM
throttle linkage for 671 blower? darkostoj Engine 1 02-17-2008 03:36 PM
buying a old 671 blower, what to look out for? darkostoj Engine 8 12-02-2007 02:06 PM
671 blower gofastwitme Engine 1 11-06-2002 06:00 AM
