69' C20 Front Brake Pressure Build Up - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2019, 12:36 PM
jimmywhale's Avatar
Greetings All,
I recently picked up a 69 C20 in Colorado as a working project truck. Just to keep me busy in the evenings. She's pretty rough, but I love these trucks and I'm looking forward to restoring it as a driver.
I have recently fully restored 72 GMC Jimmy 4WD, I did most of the work myself other than paint and electrical. So I'm no mechanic, but I know enough to get myself in trouble...
That said - I have a mystery problem on my newly acquired C20 project. The previous owner installed a front disc conversion, and I cant drive more than 8 miles without the front brake pressure building up so bad that the front discs eventually lock up. I can then wait half an hour, let it cool, and It'l drive again but only 5-8 miles again.
I replaced the front proportioning valve. I was wondering if that could be faulty.
Has anyone seen/heard of this type of problem before and diagnosed it ?
Cheers in advance for any help !
James.
PS - shiny truck and also broken truck pics below.
Shiny truck
Currently broken truck (previous owner responsible for road-runner decal - might keep it)
ID:	440461   Click image for larger version
Old 02-12-2019, 01:00 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
https://www.classiczcars.com/forums/...-the-issue-is/
The Following User Says Thank You to techinspector1 For This Useful Post:
jimmywhale (02-12-2019)
Old 02-12-2019, 02:07 PM
cozwurth's Avatar
Last journal entry: Vinyl top carnage...
We had a similar problem wi th my dad's '57 chevy with a disc brake conversion. With his, the brake pedal was not coming up enough to release the pressure in the front lines. We could put a foot under the pedal and lift and it would release. Ended up being a spring problem under the dash. Fixed that and no more problem with sticky brakes.
Sent from my SM-G900V using Tapatalk
The Following User Says Thank You to cozwurth For This Useful Post:
Old 02-12-2019, 04:21 PM
jimmywhale's Avatar
Thankyou Cozwurth. The link from techinspector1 suggested inspecting for a similar kind of issue. I might go check that out tonight and see what I find.
I have replaced almost every part of the brake system - so if it ends up being a pedal adjustment I will probably have to laugh at myself for all the hours already invested ! Thanks again.
Old 02-14-2019, 10:17 AM
jimmywhale's Avatar
Resolved thanks guys. Turned out to be a combination of both brake booster pin, and pedal adjustment. Both needed adjusting out. Took it for a 10 mile drive and so far so good. Thanks again.
1969, c10, c20, chevy, pickup
78 c20, 350 performance budget build avondj40 Engine 1 07-29-2015 06:09 PM
new video up! 69 GTO/ 69 Camaro buffed out tech69 Body - Exterior 0 12-16-2012 09:28 AM
how to build a 327 for my 63 c20 fleet side barleyco77 Engine 4 08-31-2010 12:02 PM
69 Chevy Van Brake Set-up Slammit78 Suspension - Brakes - Steering 2 02-02-2006 06:12 AM
Spun #8 on '66 model 327 C20 T56SS Engine 1 09-19-2002 04:57 PM
