Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 Chevelle quarter panel replacement
Old 08-14-2016, 02:59 PM
98camarod 98camarod is offline
Originally Posted by idrivejunk View Post
You can just carefully grind away the braze material and proceed. What makes you say the rocker needs to go? I haven't had a 69 A-body apart but on F-bodies, that vertical inner B-pillar ties to the rocker at the bottom.
It looks as if they brazed the quarter to the rocker. Isn't it supposed to be separate and the quarter is spot welded to the top of the rocker?
