Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 69 Chevelle quarter panel replacement
Old 08-14-2016, 07:54 PM
Too Many Projects's Avatar
Too Many Projects Too Many Projects is offline
Collector of "someday" cars
Last journal entry: continued
Originally Posted by 98camarod View Post
Ok, I'll give it a shot tomorrow. The repair was a skin, not a full quarter. So the original stuff is still there on the rocker.
Yep, the original is spot welded at the bottom to the rocker. Grind off the braze and drill out the spot welds and you should be good to go. Any accidental drill holes can be welded shut and ground smooth before the new quarter is attached.
