Sponsored Links | |||
This is lead removal on my 72 GP. I showed you about patching over the seam already, right? The two camaros got different style roof skins, I'm curious how yours is made at the quarter seam.
Awesome, thanks! I wasn't able to get out there due to cleaning up from the mess left and getting the family situated from the hurricane. I'll get some done tomorrow though.
The Following User Says Thank You to 98camarod For This Useful Post: | ||
idrivejunk (10-10-2016) |
I'd like to see what that roof looked like before the last "restoration"...
![]() Glad you got your power back already. |
Me too. Do you think it looks good enough to move forward?
That forward corner where the visor mount is, kinda bothers me. It could be a weak area but it only has to support the roof....unless you land on the roof. I guess the roll cage takes over from there...
![]() If you plan to have visors, I would cut that piece out and replace with good metal. I can see where they already clocked the mount around trying to find something to run the screws into. |
No visors. The cage is right there. It's a 12 point cage. I'm not worried about the body twisting, the cage makes this extremely ridgid. I actually have an extra piece in there that isn't on the other side. I have it continuing under all the way to the A pillar. I ordered the A pillar drip rail as well.
The welding is progressing as well as can be expected I reckon, considering how bad rusty it all is. This is good practice. The key with clean-to-rusty welds is to keep it on the clean side and drag it barely onto the rusty at the end. Heres a few tacks like that which I recently did. Doesn't look much different!
![]() Along the lines of what Mitch said... Nobody wants to hear the windshield pop loose over there or crack. I'd like to see you make a flat patch over the whole visor mount area. Where the square hole used to be complete, with the rolled edge. Just go over the top of that and tie in to the new little angled piece and grab the end of the cross brace reinforcement also, the 90 degree piece that sticks up. What do you guys think? |
That was my area of concern. In his 7th pic, if he made a patch to go over the entire triangle shaped hole and tie in to the header, it would help compensate for all the metal that is missing and badly rusted in that corner.
Exactamundo! It would be in the lower left corner of the last (9th) pic but extend past the pic's bottom a little. Lots of plug welds rather than edges where possible please. Gotta get good at those sometime! Anytime you can get the good steel behind (below) the rusty stuff, thats preferred for ease of welding.
I'd say if there's no witness marks left to show the old drip rail position, start by clamping the rails to the skin. Let the roof corners fall where they want to then connect the rails to the beam. I've not replaced drip rails so that's a guess. Manipulate the rail rather than the skin to match things up. Fore and aft positioning of the rail could be roughly determined referencing your new A pillar rails. The visor area thing isn't what I had in mind but does probably help it.
Recent Body - Exterior posts with photos |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
1970 chevelle quarter panel replacement | Lovemius | Body - Exterior | 3 | 06-14-2014 04:33 PM |
quarter panel replacement | 81camaro1 | Body - Exterior | 7 | 10-06-2013 10:39 PM |
67 Mustang Quarter Panel Replacement | Morgan22 | Body - Exterior | 8 | 07-16-2010 03:30 PM |
Quarter Panel Replacement | jakejake1966 | Body - Exterior | 2 | 07-05-2006 08:56 PM |
quarter panel replacement | 38chevysedan | Body - Exterior | 3 | 10-30-2005 08:58 PM |
