69 Chevelle quarter panel replacement - Page 9 - Hot Rod Forum : Hotrodders Bulletin Board
  #121 (permalink)
Old 10-04-2016, 06:20 AM
Well atleast it looks better now.
  #122 (permalink)
Old 10-07-2016, 07:06 AM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
You have everything battened down ?? Probably no Chevelle work this weekend...
  #123 (permalink)
Old 10-07-2016, 07:35 AM
I do as much as possible. I've been working on my nova. The powerglide won't stop overflowing the catch can. Found out it has a ringless shaft without proper rings for the cooling circuit. So it's all apart now. I'm going to bag all of it and get back on the chevelle while I have power and waiting for parts.
  #124 (permalink)
Old 10-07-2016, 09:37 AM
Also a weird thing. My roof skin and drip rails arrived. The drip rails are only for the roof skin. So what the hell am I supposed to do with that?
  #125 (permalink)
Old 10-07-2016, 10:59 AM
Are you saying they don't extend all the way to the bottom of the quarter glass ??
  #126 (permalink)
Old 10-07-2016, 12:24 PM
They are just for the roof skin and don't include the A pillar portion. I got this done. I guess this is the right way to go about it.
  #127 (permalink)
Old 10-07-2016, 03:33 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
That works for me, just as long as after grinding theres no interference. What did you black it with? I don't know what to call those vertical drip rail pieces but I found em-
https://www.opgi.com/chevelle/C240577/
They usually screw on, not sure on your car but Camaros do.
  #128 (permalink)
Old 10-07-2016, 05:18 PM
Awesome, thanks! I just used the rustoleum brush on gloss black.
  #129 (permalink)
Old 10-07-2016, 05:31 PM
I got back to the party too late to say the A pillars are a separate piece.
Looks good, but, and I'm not being critical, it looks like you could turn the amps up a little for that heavier metal. The welds don't look like they have enough penetration and are building up a lot. OR, if they do have penetration you can turn the wire speed down a tad.
  #130 (permalink)
Old 10-08-2016, 03:20 AM
Thanks for the advice. I tried to bump it and blew threw so just backed it down. I'll grind it down and give it one more go and another grind down.
  #131 (permalink)
Old 10-08-2016, 07:18 AM
idrivejunk's Avatar
Grand Prix User
I actually had visualized a plug welded patch for those areas. Maybe several small ones with a horizontal bend for strength and placed inside the beam if possible. I know that metal is probably like tinfoil. Having the patch inside the beam would allow hotter plug welds. Not sure my way would serve any better though, so I didn't rock your boat.
  #132 (permalink)
Old 10-08-2016, 07:33 AM
I thought about doing it that way, but I couldn't figure out a way to make it connect the entire structure. I also found it easiest to not weld in a rusted spot. I just have this sheet metal experience and any time there is rust, it blows right through. I'm assuming it's due to it being thin, not clean in the pours, deteriorated metal. I had to whip up a brass spoon to do the giant plug on the left of the rear patch. The rear patch was rusted on the underside as well so I cut that out too. I welded that in first and welded to that for the outside patch.
What's the best tactic for the front portion on the passenger side?
  #133 (permalink)
Old 10-08-2016, 08:12 AM
idrivejunk's Avatar
Grand Prix User
First, get the lead out and clean the whole area. I'm having trouble discerning the layers there. Perhaps one of my Camaro threads has a telltale pic of that spot. But you have the other side to look at too, as far as how the panels stack. It might not hurt to screw a simple brace of some sort to the side beam and the front cross brace so nobody moves.
Once it's prepped for surgery I'd hack off that top part over the visor with the funny shaped hole, keeping it as intact as possible. Patch up that piece, make the part that's gone and fit that piece but don't weld yet. Proceed to the next layers working your way down with the same approach. Use your judgement about what contours are essential to duplicate closely, and just make the rest sturdy.
I'll switch to PC shortly and see about finding relevant pics, there should be plenty from the Camaros. You'll probably have it fixed before I can find em lol. But check back.
  #134 (permalink)
Old 10-08-2016, 08:17 AM
Ok thanks. I wish I could say you are right, but the hurricane knocked my power out. So who knows when that is coming back.
  #135 (permalink)
Old 10-08-2016, 08:50 AM
idrivejunk's Avatar
Grand Prix User
Sorry about that, I've been in a soggy mood lol.
Matt
1970 chevelle quarter panel replacement Lovemius Body - Exterior 3 06-14-2014 04:33 PM
quarter panel replacement 81camaro1 Body - Exterior 7 10-06-2013 10:39 PM
67 Mustang Quarter Panel Replacement Morgan22 Body - Exterior 8 07-16-2010 03:30 PM
Quarter Panel Replacement jakejake1966 Body - Exterior 2 07-05-2006 08:56 PM
quarter panel replacement 38chevysedan Body - Exterior 3 10-30-2005 08:58 PM
