69 olds 98 turbo 400? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2019, 12:38 PM
Hello,
Car has been sitting for 12 years ,Grandmas, it started up ok but no reverse.Whenin reverse it blew trans fluid out of fill tube all over the place.
Was that from over heating and boiling the fluid?
Thanks
Old 08-13-2019, 04:55 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Maybe grandma overfilled it.
Did you check it after you ran it through the gears?
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
57fever (08-13-2019)
Old 08-13-2019, 06:03 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by 57fever View Post
Hello,
Thanks
typical cause of fluid blowing out the filler tube is a clogged vent on the transmission case. Insects of some type often are the cause of a clogged vent
The Following User Says Thank You to Crosley For This Useful Post:
joe_padavano (08-13-2019)
Old 08-13-2019, 08:27 PM
Old(s) Fart
Last wiki edit: Wheelbase database
^^^THIS!
I had exactly this problem on the TH400 in a 67 Olds Delta. Here in Northern VA, the flippin' mud daubers plug up every hole they find. I have engine blocks in storage where every bolt hold is plugged like that.
The Following User Says Thank You to joe_padavano For This Useful Post:
57fever (08-14-2019)
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
