Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 lock up control switch queston
Old 09-06-2011, 05:05 PM
63ChevyII.com 63ChevyII.com is offline
Thanks. With the internal wiring the way that it is, do you think Pin D should be 12v and Pin A ground?
If I swap out the pressure switch, should I redo all of the modified wiring, or do you think it's ok as is?
