700r4 tranny doesn't work properly - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2007, 11:21 AM
i got a 700r4 tranny and it doesn't wanna down shift when the pedal is to the floor...once in a blue moon it will but then the rpms keep going up and up to like 7000 and it doesn't shift to the next gear unless i leave off of it what could be the problem..i'm thinking about installing a shift kit. hopefully that will help a little..Also when i take off and it shifts but the rpms also shoot up. any ideas
Old 04-15-2007, 11:51 AM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
Sounds like the TV cable needs adjusting.
I wonder if common sense will ever make a comeback?
Old 04-15-2007, 12:36 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you describe a multitude of problems.
Check the fluid level. Low fluid can cause problems. Over filled will cavitate the fluid ( put air into it) , this will cause erratic PSI inside the trans
Check the TV cable operation and adjustment.... full pull of the TV cable at wide open throttle.
Geometry must be correct at the carb/EFI for TV cable operation of the 700/4L60 trans.
RE: the above comment.....
are you saying the engine RPM flares UP during a shift? Which shifts?
During the 1-2 shift? Indicates a band / servo / pressure problem
During the 2-3 shift? Indicates a 3-4 clutch or pressure problem.
If your motor is spinning to 7,000 RPM the trans could be starving for fluid from a dirty fluid , low fluid level .
Old 04-17-2007, 04:03 PM
how would i go about adjusting the tv cable...when 1st gear goes into 2nd it shifts but the rpms stay where they are and then drop. when 2nd goes into drive the rpms flare up and then it shifts. drive to overdrive is ok. the transmission was just put in like a year or so ago. i payed $1400.00 for the tranny before this one and after about 2 years of driving it normally back and forth to work drive and overdrive went out of it. so i got this one from the old junk yard. it ran fine when it was put in. i guess it's at the end of its chain
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 02:04 PM
700r4 tranny pump nannie Transmission - Rearend 12 09-24-2005 10:49 AM
700R4 Tranny Problem Jugg3rnaut Transmission - Rearend 2 08-21-2005 02:56 PM
Would a 4spd manual tranny from a late 60's chevy Camaro work in my truck. mercflathead Transmission - Rearend 1 06-19-2005 09:35 PM
700r4 ? for Crosley or other tranny xpert onelowzuki Transmission - Rearend 5 10-18-2003 10:12 PM
