71 gm fuel system - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2009, 10:47 PM
71 gm fuel system
i just recently put a crate 350 gm in my 71 lemans... yes i know but it was cheaper and i dont have the money. anyhow. i have it all hooked up and ready to run. but.... i am having problems getting gas from the tank to the motor. the pump is good. i tested that. the line is clear from the pump to the tank. i dont know what to do anymore. could i by pass all the other lines and just run a line to the pump and a return line? other suggestions.. help!
Old 07-10-2009, 11:18 PM
RODDER18's Avatar
When you pull the line off the pump does fuel come out? If not it could be a plugged fuel filter or rust in the tank plugging the outlet. Is it a mechanical pump or electric? How did you test the pump? Is a rubber hose kinked? Check the obvious first.
Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines J.J. LASALLE General Rodding Tech 6 06-29-2009 01:04 AM
Need help building a fuel system. staleg General Rodding Tech 1 05-16-2007 01:13 PM
!!!!! HELP - CARBURETOR LEAKING & FUEL TANK NEEDS TO BE CLEANED!!!!!!!!!!!!!!!!!!!!! islandman Engine 3 03-17-2007 03:36 PM
Fuel System 41willys General Rodding Tech 2 10-08-2005 08:17 AM
