Hot Rod Forum : Hotrodders Bulletin Board (https://www.hotrodders.com/forum/)
-   Engine (https://www.hotrodders.com/forum/engine/)
-   -   81 El Camino Engine Swap Question (https://www.hotrodders.com/forum/81-el-camino-engine-swap-question-117771.html)
newdad1 06-09-2007 08:42 AM
Hello,
I just purchased a ' 81 Elcamino that is in good shape. According to the label on top of the radiator, the motor is a 4.4 liter aka 267 cubic inch. I didn't know chevy made these.
Anyway, I pulled the motor and transmission out yesterday. I am going to put a 4 -bolt main 350 that has been completly rebuilt, and needs to be started for the first time/broke in etc. I am not using the AC that came with the car. With the exception of the starter wires, battery cables, engine/chassis ground strap, distributor "Batt/Tach" connection, what other wire do I have to have hooked up in order for it to run?
Also, before I put the engine and transmission back in, I need to clean the engine compartment up. I have a pressure washer. What can I use to clean/degrease the engine compartment without having to worry about shorting anything out?
Thanks.
400smb_s10 06-09-2007 11:17 AM
Your local auto parts store should have a degreaser/detergeant that you should be able to put in your pressure washer. Or you can buy some degreaser in a can and soak the engine bay let it sit for a while 10-15 mins and then spray it off completely and then respray the degreaser and wash it off again and it should be squeaky clean.
