81 El Camino Engine Swap Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2007, 09:42 AM
Hello,
I just purchased a ' 81 Elcamino that is in good shape. According to the label on top of the radiator, the motor is a 4.4 liter aka 267 cubic inch. I didn't know chevy made these.
Anyway, I pulled the motor and transmission out yesterday. I am going to put a 4 -bolt main 350 that has been completly rebuilt, and needs to be started for the first time/broke in etc. I am not using the AC that came with the car. With the exception of the starter wires, battery cables, engine/chassis ground strap, distributor "Batt/Tach" connection, what other wire do I have to have hooked up in order for it to run?
Also, before I put the engine and transmission back in, I need to clean the engine compartment up. I have a pressure washer. What can I use to clean/degrease the engine compartment without having to worry about shorting anything out?
Thanks.
Old 06-09-2007, 12:17 PM
400smb_s10's Avatar
Back Yard Junky :)
Location: Around the Corner from the middle of nowhere... Arden Ontario
Your local auto parts store should have a degreaser/detergeant that you should be able to put in your pressure washer. Or you can buy some degreaser in a can and soak the engine bay let it sit for a while 10-15 mins and then spray it off completely and then respray the degreaser and wash it off again and it should be squeaky clean.
1971 el camino 350 colincamaro Engine 1 10-21-2006 07:15 PM
Newbie engine swap question sdj02 Engine 5 10-15-2006 05:02 PM
1982 el camino cc070890 Introduce Yourself 2 07-02-2006 07:30 AM
engine swap question earthworm Engine 17 12-08-2003 02:53 PM
87 El Camino engine swap lscott046 Engine 1 01-31-2002 09:19 PM
