Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 81 El Camino Engine Swap Question
Old 06-09-2007, 08:42 AM
newdad1 newdad1 is offline
Hello,
I just purchased a ' 81 Elcamino that is in good shape. According to the label on top of the radiator, the motor is a 4.4 liter aka 267 cubic inch. I didn't know chevy made these.
Anyway, I pulled the motor and transmission out yesterday. I am going to put a 4 -bolt main 350 that has been completly rebuilt, and needs to be started for the first time/broke in etc. I am not using the AC that came with the car. With the exception of the starter wires, battery cables, engine/chassis ground strap, distributor "Batt/Tach" connection, what other wire do I have to have hooked up in order for it to run?
Also, before I put the engine and transmission back in, I need to clean the engine compartment up. I have a pressure washer. What can I use to clean/degrease the engine compartment without having to worry about shorting anything out?
Thanks.
