Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 89 350 TBI running poorly
  #31 (permalink)
Old 11-05-2015, 05:26 PM
69612 69612 is offline
Guest
Location: in the land of Trolls at least till the san andreas releases the big one
Originally Posted by Jrclayt View Post
My oil pressure gauge is normally maxed out will occasionally on a perfect day work intermittenly. So Oil pressure sender could actually be the root cause of this. I will check the relay tomorrow in the light and if it dies ill replace the Oil sending switch and go fromt there. Also another thought i had, if my Injector(s) are fouling out at Operating temp could that cause it? After it warms up i noticed today it has a slight miss. But only does it in closed loop at normal operating temp.
with a hot misfire.. i would examine the ignition coil for signs of high voltage leaks.. white marks around the outside of the windings. there is a chance your injectors could be shorting internally..
