89 350 TBI running poorly - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 11-05-2015, 06:26 PM
Guest
Location: in the land of Trolls at least till the san andreas releases the big one
Originally Posted by Jrclayt View Post
My oil pressure gauge is normally maxed out will occasionally on a perfect day work intermittenly. So Oil pressure sender could actually be the root cause of this. I will check the relay tomorrow in the light and if it dies ill replace the Oil sending switch and go fromt there. Also another thought i had, if my Injector(s) are fouling out at Operating temp could that cause it? After it warms up i noticed today it has a slight miss. But only does it in closed loop at normal operating temp.
with a hot misfire.. i would examine the ignition coil for signs of high voltage leaks.. white marks around the outside of the windings. there is a chance your injectors could be shorting internally..
  #32 (permalink)
Old 11-06-2015, 06:05 AM
Jrclayt's Avatar
Alright I'll have to check that. When it starts running poorly it almost sounds like a small exhaust leak. I don't have an exhaust leak is the issue. I'll check and let you know.
350, c1500, chevy, tbi
351w running poorly at times Leesanford6689 Hotrodding Basics 3 01-28-2015 08:58 PM
carbed Rv 350 swapped into a TBI k5 running poorly Tile guy Engine 14 06-04-2014 09:07 PM
89 tbi 5.7 running poorly no power at low rpm or half throttle monsterchevy355 Modern Electronic Engines 3 03-10-2012 08:25 PM
hard running TBI 350 punk1c5040 Electrical 11 12-23-2003 10:47 PM
Poorly running 327 question 54 Chevy Engine 4 09-01-2003 12:58 PM
