9" ford axel bearing --the the seal tool - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2017, 02:58 PM
bsa_bob2's Avatar
I assume as i have the new bearing installed on the axel shaft, It will slide right in, am i right??????????WHAT tool does one have that will suffice ..for beating the new seal in. Do i have a tool makeshift..maybe you made one up? thanks for looking bob s
Old 02-10-2017, 04:06 PM
On a 9 inch Bob the bearing (usually) is a sealed unit and does not receive lube from the housing. The seal goes toward the inside of the bearing and is driven into the axle housing. I used a slide hammer with a hook on it to pop my old seal out and anything that is just smaller than the axle bore to install the new one. Of course they do make seal drivers but most of us old country boys use whatever is at hand.
AAMOF I have to install mine tomorrow.
Just be carefull and don't damage the seal.
John
Old 02-10-2017, 06:18 PM
bsa_bob2's Avatar
thank you much John! Really appreciate the quick reply. Just a large ball peen hammer,And short piece of 2" pvc Went in as they are supposed to.thanks John for the quick reply great weekend to you bob s
The Following User Says Thank You to bsa_bob2 For This Useful Post:
John long (02-10-2017)
Old 02-12-2017, 10:31 AM
bsa_bob2's Avatar
Ihave the new wheel bearings installed . question the axel and attached bearings should just slide right in the housing .Mine don't what do i look --for i miked....070 on the axel opening--- and the miked----dia of the new bearing.Looks like its not getting past the edge of the backing plate. thats bolted on to the housing. Got my own answer there think.? I just wiggle the loosened B/P around till the bearing drops in?? right? THANKS BOB S
Old 02-12-2017, 11:56 AM
You very well may be right but remember the axle ends must slide into the third member and mate with the splines. Until you get the axle alligned in the third member it will not slide in.
I suspect though that you are already on the right track.
John
FORD 9" bearing size? johnny-bravo Transmission - Rearend 5 09-01-2016 07:59 PM
Ford 9" big bearing V8juggernaut Transmission - Rearend 2 05-05-2015 07:25 PM
"tapered" rear axel bearing question powerrodsmike Transmission - Rearend 3 08-10-2007 05:47 PM
Ford 9" Carrier Bearing Preload Help dsmith1279 Transmission - Rearend 3 07-30-2007 01:40 PM
9" ford bearing question 85406 Transmission - Rearend 3 01-03-2005 09:58 PM
