92 corvette tpi in 36 coupe idle speed - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 05-15-2019, 06:31 PM
Have a 92 vette tpi in my 36 coupe,running at 950rpm at idle,any ideas gentlemen how to reduce idle speed, bad idle sender? Thanks the aussiebloke
Old 05-15-2019, 06:43 PM
Talk to your computer.
Could be many things. Even something as simple as a soft cracked vacume line.
Plug in a tester and run the codes.
Old 05-15-2019, 07:15 PM
64nailhead's Avatar
Checked for vacuum leaks? If you adjust the throttle plates closed it should stall - does it do that? If not then either intake leak or malfunctioning IAC.
I should ask, how does it run going down the road? Smooth, no smoke, normal?
Old 05-15-2019, 07:18 PM
39 master's Avatar
Have you set the idle step motor as per instructions?
Old 05-15-2019, 07:57 PM
Idle step motor?
Old 05-15-2019, 08:04 PM
Idle step motor?
Old 05-15-2019, 08:06 PM
Good smooth,no smoke
Old 05-15-2019, 08:21 PM
Maybe idle air control maybe?
Old 05-15-2019, 10:12 PM
39 master's Avatar
The idle step motor is located under the throttle body and controls the idle thru an air bleed bypass. There is a procedure for setting the I.S.M. and can be found online. There is a link that must be disconnected before setting the motor, good luck finding it. Been my experience the I.S.M. gets carbon deposits and cleaning will help. Again, the procedure can be found on line. Also note high idle is caused by the step motor.
Recent Modern Electronic Engines posts with photos
Holley metering block function eric32 Hotrodding Basics 2 07-02-2016 07:54 PM
Engine Idle Too Fast With New Carb Canadian Charlie Engine 15 11-17-2010 09:21 PM
Odd Idle - 79 Corvette with zz4 jgp137 Hotrodding Basics 19 04-21-2010 12:35 PM
88 Corvette tpi with Turbo400? wayja Transmission - Rearend 2 05-25-2003 08:37 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
