94 Buick RoadMaster Estate Wagon LT1/ TPI question - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
  #76 (permalink)
Old 06-27-2019, 01:07 PM
Toward the end of my OBD 1 computer I had to reboot so much I put a switch in the dash so I could just turn the power off to it when ever I shut down. I finally just made a permanent conversion to a carb rather than do any more fixes to the computer system.
A problem you have with the Buick is it isnt exactly an OBD 1 and it isnt an OBD 2 but it is a little of both.
You've been through exhaust leaks, possible sensor failures and replacements, most everything yet the problem persists. I'm thinking that like my old OBD 1 it's getting down to the computer itself having brain farts. These things don't last forever. It didn't die suddenly it just got increasingly haywire hardly noticeable at the start but enough that since I design these systems for aerospace I knew from experience that it was starting to die. As a step alng the way it turned out the 4l60E died the 3/4 clutch death so I replacd it with 700R4 which didn't need the computer. The computer over the next couple years got flakier and flakier. So did my heart so I had to take time out for a ring and valve job on that, so in the latter months of recovery I went to the shop and replaced the EFI with a carb and intake. If nothing else that simplified the underhood wiring mess of GM's.
I had to relearn how to operate a carb, no more just turn the key and it starts, the fuel mileage isn't as good, I can duplicate the mileage of the EFI but you have to work at it, it doesn't just happen. The down side is that isn't much fun.
The LT 1 and 4 can be converted to a carb and conventional HEI with a GMPP carb intake. It is possible to retain the 4L60E with a throttle position sensor and tach signal to the computer if it still knows how to shift gears in its old age.
Bogie
  #77 (permalink)
Old 06-27-2019, 06:38 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
When I worked at CHEVROLET in the late 80s and early 90s we considered an injector cleaning to be periodic maintenance.More so than a tuneup. Fuels were borderline sludge and injectors were finicky.
We would hook the alternative fuel/detergent supply to a warmed up engine and start it.Prop the throttle at 2500 rpm and stand back and listen for a few minutes. You could hear cylinders changing tune as they fired, misfired and eventually cleared up. At the end it wasnt uncommon to have the engine running at 3000 rpm or a bit higher due to the improvement that cleaning made.
It isnt changing parts, it is just cleaning what you have . You should try it.
Fact is stranger than Fiction
  #78 (permalink)
Old 06-28-2019, 11:53 AM
bentwings's Avatar
bentwings
In my quest for knowledge on this system I came across “smoke testers” for leak detection. There are some videos and methods of use. Using the power brake port was a good one shown in static test.
There are commercial ones of various prices then some home made ones.
The pressures noted are very low....1-2 psi. Only 4” HG. It would seem to me that you would have to block the exhaust system on both sides and still have a very dense cloud to see anthing on the intake system.
Any comments?
  #79 (permalink)
Old 06-28-2019, 03:44 PM
I'll go back to where i was yesterday, that being that computer chips don't last forever.
ROMs, EPROMs which are at the heart of these EFI and vehicle management systems have a reliable life span of 10 to 15 years, and that's measured in a benign environment like a building. Anything longer is an uncalculated gift of the computing gods. As these devices age out they just get forgetful resuluing in holes forming in their programming. Of the sensors that are sending data to the program that sums to an address that has fuel or timng data stored there and that location has lost function, you will see an error code genetated against the subject sensors. Another common event is the CEL comes on but will not read an error code, or the error code displayed makes no sense to the encountered problem. Back in my earlier aerospace days we used to joke that it was the function of "Built In Test Equipment" (BITE) to point to the other guy as causing the error. What that really gets down to is you as designer, tester, mechanic, or technican need to have a good view of the wider system and how the parts work together inorder to decipher the true meaning of the codes you see. This isn't an all the time thing but when the codes don't match what's happening, or fixes to the stated error don'tchange anything this is a good sign that the problem as stated isn't really the problem.
Think of it as Alzheimer for computers, I had an uncle that had thi (as a human); when he had to pee he went to the refrigerator to do this business. Shows you what living in Cleveland and working at the POC brewery all your life could do to you.
Bogie
  #80 (permalink)
Old 08-15-2019, 09:27 AM
bentwings's Avatar
bentwings
Boggie, you know we have done virtually everything
to the car/system, lately my guy and I discussed installing new injectors. We weighed the tests and what’s going on and what’s not going on. I hate throwing parts at these things and the more I get into the EFI the more I see this happening. The latest was a smoke tester top if the line thing to test for suspected leaks. It showed no leaks anywhere. Then another compression test..normal and another set of new plugs on the right bank. Still the same issue. The right bank is dead max rich.
So at this point we have no options but to start with the computer. So I have to apologize for taking your comments lightly. We have a guy coming over that reflashes these. Flames it happens more often than you think. I also discovered that Rockauto has rebuilt computers and the EPROM available. Hefty core charge too.
So I may have to go this route. It really gets under my skin as the car ran so good then just overnight it started acting up.
But like you said these things don’t last forever. Is just the testing frustration of ot being able to identify the issues.
  #81 (permalink)
Old 08-22-2019, 11:33 AM
bentwings's Avatar
bentwings
The guy that does does the Reflash said he can’t do these. No reason given at this point.
I kinda lost it I guess, I just said fix the dam car, I need it quickly. I’m really tired of screwing around with it.
Virtually everything is pointing to the computer. What elas can it be? I did. Chat with a detailer and he said he no longer pressure washes cars under the hood. He did it on one and it acted like it had been submerged. Nothing ever really worked correctly. He said it cos,t him a fortune to fix it.
The new computer is on the way complete with the new EPROM. Hopefully by the week end.
Meanwhile my Quadrajunk el Camino just purrs on. It starts instantly cold or hot doesn’t get very good mpg but at least I get there. I have two of them on the boat that I just don’t have time to go through so I’m taking them to The Carb shop. A nationally know carb rebuilder. He said he could turn them around pretty quickly.
  #82 (permalink)
Old 08-22-2019, 08:38 PM
Hey I'm not wanting to hijack this thread but I wanted to share my experience and help I got from this thread, I just rebuilt my 94 chevy 5.7 in my k1500 z71, made it into a mild 355 and it runs great, anywho I was experiencing some weird things kina like what you have had going on and couldn't pin it down to one thing it kept messing up and idling extremely rough and missing and then it would just suddenly clear up and be fine, I'd think it was all fixed, and then a couple days later it would do it again and throw in some new wacky stuff just to make it interesting, I got a cable and using aldldroid I checked just to see if there was anything noticeably wrong or if it would give me a code but it all seemed peachy. Well after reading bogies post about "crusty" computers I thought well I could try it, as I'm wanting to tune it myself down the road I figured it would be good to start with a fresh computer anyway. Found a company on Ebay that reflashed them, swapped memcals, plugged it in and bam! Usually it would turn over for a couple seconds before firing off but not tonight, I hardly hit the starter before it went off and ran so beautifully, no miss no rough idle, no weird hunting anymore. So far I'm very happy and I hope that fixes your problem. Thanks bogie and all the guys on here with the great info
  #83 (permalink)
Old 09-02-2019, 12:13 PM
bentwings's Avatar
bentwings
I hope that happens tomorrow when I stop by or call the shop. Somehow I have a gut feeling it’s more of the same.
I did find my laptop and scanning cable so I can deep scan right away. I think I’ll bring it along so I can compare scans. If irs running great I’ll be sooo happy.
  #84 (permalink)
Old 09-30-2019, 12:52 PM
bentwings's Avatar
bentwings
We replaced the computer with a new one and the problem is still there. No change at all.
A very long story short, we are removing the intake and replacing the gaskets. The intake is getting cleaned including the idle air passages.
We revisited the exhaust manifolds and they seem good looking as them from above and below. There is no exhaust noise indicating a leak.
If this doesn’t fix it, I’ll take the car to my sons shop and plan on spending a day at a time going over this thing.
I think we simply missed something.
  #85 (permalink)
Old 10-02-2019, 12:29 AM
I'm sorry to hear this, it sounded like everything, everywhere was checked out or replaced, and having been that road a few times myself that left the computer itself. But indeed it sounds like something got missed in the earlier diagnostics. As to whether that is mechanical or electrical remains to be settled and winter is coming on, no pressure though.
Bogie
  #86 (permalink)
Old 10-02-2019, 06:50 AM
bentwings's Avatar
bentwings
I was supposed to hear the results of the manifold R&R plus cleaning Fri but I think they took off for duck hunting. They are supposed to be in today, so Iíll call then or stop by.
I emailed him a note to be sure to clean the idle air passages. Since Iíve not seen one of these manifolds up close I didnít know about where they are or that they feed each port. They are reported to be a cause of this very problem however in my searches only one person noted this.
I still have an uneasy feeling that this is not the problem. Gaskets yes and I hope that does something.
Should this not fix the car I think Iíll take it back and bring it out to my sons shop. Itís a long drive so I might only be able to work on it one day a week.
A new computer was installed after reading your post and some discussion.
So now virtually every system has been addressed.
The wire harness itself now becomes the issue. There are lots of connectors on it so possibly just separating them and cleaning might help.
Iíll try the U pull and see if I can find an exact model. I donít know if Firebird and Camaro are the same.
So Iíll know more later today, I hope.
Thanks for the help.
  #87 (permalink)
Old 10-02-2019, 12:52 PM
I ended my aerospace engineering career in electrical; the subject I hate the most. They make such a big deal out of it, after-all it's white to white, black to black, red to red, green to green; what could go wrong?
Bogie
  #88 (permalink)
Old 10-02-2019, 05:40 PM
123pugsy's Avatar
Purists Hate Me
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
How about the injectors?
Have they been cleaned? Wires confirmed to be solid?
I feel for you. This is insane.
  #89 (permalink)
Old 10-02-2019, 09:38 PM
bentwings's Avatar
bentwings
The injectors and orings have been replaced and are new.. this car had a pampered life so it was very clean under the hood when I got it. The wire connectors may have a little dust on them but the connections seem pretty clean and not corroded. It never saw a winter.
Bogie, I ended work as mech engineer and still eat, live and sleep it. As for electrical, you should see boats. I now live on one and a rat’s nest would be fine art compared to boat wiring. The only way to test wiring is start point to end point for resistance and continuity. Color no longer matters. Wires go everywhere sometimes tiewraped, some are taped most just hang there. A very large bundle is fiberglassed into a corner. The wiring diagram is just art work. It would have failed 7 grade drafting. I sometimes wonder if it is really lettered in English. I’m surprised anything works. There are inline fuses everywhere. None in the main control panel.
Almost as frustrating as this car.
The Following 2 Users Say Thank You to bentwings For This Useful Post:
123pugsy (10-03-2019), BogiesAnnex1 (10-17-2019)
  #90 (permalink)
Old 10-17-2019, 04:25 PM
I'm thinking in terms of fire wall connectors as well as what's on the engine. You can also throw that mess under the dash in there as well.
Bogie
Recent Modern Electronic Engines posts with photos
what engine? 77 buick estate wagon roadlet_411 Engine 15 04-27-2010 10:29 PM
1962 Buick Electra 225 LT1 Swap crazycasey General Rodding Tech 1 02-05-2010 05:00 PM
b or g hemi joe Body - Exterior 5 05-03-2009 03:50 PM
'96 roadmaster LT1 compatibility HOUCKXLR8 Engine 9 04-17-2007 11:43 AM
Buick Roadmaster stanray Introduce Yourself 2 02-06-2007 07:06 AM
