95 Silverado - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2014, 11:33 AM
95 Silverado
I have a 95 single cab Chevy silverado with a crate 350 (TBI) and a 5 speed transmission, but my rev limiter is only at 3600! Why? What do I need to do to get it higher? The motor is a new crate 350 with about 50,000 miles, the transmission is from a pull apart so the motor and tranny did not come stock with this truck. I've seen trucks like mine, rev limit at 5 grand. I just want mine to be up there! So what should I do!?
Old 03-07-2014, 12:03 PM
Wiki Edits: 31
Someone swapped a M/T into an Auto truck.. Thinks it's in park. Either get the right ECU, or figure out how to make it think it's out of park..
the 5spds did not have a rev limiter. My '95 would sing right to 6k if I wanted it to
Old 03-07-2014, 04:11 PM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
Are you sure it has a rev limiter, or is it just running crappy?
I have a 97 with auto trans, I dont think the revs are limited, although I dont think I have ever had to rev it that high anyways.
Old 03-07-2014, 04:42 PM
Banned
have a 95 myself with a 5 speed i never even hit 3500. in 5th it is about 1500. if you are at 3600 that thing must be screaming .
Old 03-07-2014, 04:52 PM
jokerZ71's Avatar
Wrench Turner
Factory rev limits are usually set @ 5500.They be can raised to 5800,but,that is hardset unless you use the newer 0411 controller.If your engine just won't rev past 3600,you either have a problem,or,someone has set it that way for a reason,or,thru mistake.What happens @ 3600?Are you sure the tach is reading correctly.IIRC,if the truck & PCM are from a V6,it will need to recalibrated for the V8.
Old 03-07-2014, 05:30 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Never drove a 95 Silverado that I couldn't wind up to 5500. Red line is somewhere around there. No rev limiter to my knowledge on a rig that old.
More info is needed. Was the truck originally a automatic? Park neutral switch could come into play as timing is altered in park and neutral somewhat.
Was the truck a 4.3? was it originally an automatic?
Have you checked the fuel Pressure?
Fact is stranger than Fiction
Old 03-09-2014, 12:20 PM
1993 trucks all have a rev limiter. Put it in park or neutral and hold te throttle wot and it will sit there hitting the rev liiter "Wha, wha, wha, wha".
1996+ its set at 5600rpm
The 1993+ trucks used the 4l60e and if you swap in a manual trans the rev liit will be very low.
The 1992 and older trucks didnt have a rev limiter.
You need to get the proper calibration for a manual truck installed to rev any higher. The ECM is entering abuse mode.
peace
Hog
Old 03-09-2014, 12:45 PM
astroracer's Avatar
Last wiki edit: Crankshaft Coalition Wiki
My '95 Sierra would hit the limiter at 4K... It is a 4L60e. I put a Hyper-tech chip in it to eliminate the limiter.
Mark
Old 03-10-2014, 05:12 PM
How was the truck originally equiped, engine, transmission, rear end?
Transmission not original; where/what did it come from; make, model, year?
Is the computer original?
Does the speedometer read correctly?
Bogie
Old 03-10-2014, 05:45 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Pop the glovebox. If it has the RPO code M30, it was an automatic trans from the factory.
350, chevy, rev limit, silverado, tbi
85 silverado otis-larry Introduce Yourself 2 01-05-2012 07:15 AM
Silverado 83SILVRADO Introduce Yourself 4 02-22-2009 09:02 PM
'86 Silverado chevelle_man64 Engine 11 12-31-2008 05:15 PM
My 82 Silverado Hotrodpatton1969 Introduce Yourself 2 02-11-2007 09:36 PM
79' Silverado Codizzle Skillet Electrical 2 09-17-2006 04:19 PM
