98 Ranger XLT: 351W conversion ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2018, 03:14 AM
Got a 98 Ranger XLT, std. cab 2wd in a trade. Has 2.5 auto, 3:73 open diff.
I know the 302 is the easy way to swap, but I've always been a sucker for a bigger engine. I've even thought about a 400M, these can be fun when the smog crap gets discarded and a head/cam swap.
But about the 351W (easier swap that is most likely to happen for me), any good headers or stock exhaust manifolds for these? And running AC too, could use a Sanden comp. to limit size. And a C4 trans, old Bronco 9" rearend with tamer ratio. Emissions not a concern.
Anything I need to think about that I'm missing? I know I'll need some mods on the heater box...
Old 12-09-2018, 07:07 AM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
A 3 inch body lift will give you the clearance you need at the heater box
A 351 W is a great choice.
Sounds like a cool build.
Fact is stranger than Fiction
Old 12-09-2018, 09:30 AM
Wiki Edits: 31
No need for a 9". The Ranger 8.8" is still a stout rear axle. If you want discs and traction lock, then the Explorer rear is a cheap bolt in. little stronger ( 31 spline vs 28 iirc ) and it flips the axle over the leafs for a lower stance
Old 12-09-2018, 03:10 PM
ericnova72's Avatar
More for Less Racer
You'll likely get more info over at the Ranger Station forum, in the Engine conversions section.
Not trying to run you off here, just that they specialize in the Ranger topic
https://therangerstation.com/forums/...=95640&page=14
https://therangerstation.com/forums/...ad.php?t=95640
Garage find 1990 Ford Ranger XLT What to do with it? captainbob Hotrodders' Lounge 4 11-03-2014 05:58 AM
2000 Ford Ranger 4X4 XLT Front hub torque MaryMac General Rodding Tech 1 06-02-2012 11:52 PM
1970 ford f100 ranger xlt questions? 722wdblazer General Rodding Tech 7 05-13-2012 06:55 AM
1972 Ford F100/Ranger XLT Fordfreak1966 Transmission - Rearend 2 09-20-2010 12:56 AM
1980 Ford Ranger XLT w/ 351M engine and C6 trans. wildfly Hotrodding Basics 9 01-03-2006 09:25 PM
