Accidently went into reverse @ 20 mph!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2006, 12:20 PM
My car was overeheating so I went to put it in nuetral and coast off the road and I accidently went into reverse. I was still going about 15-20 mph when it happened. It slammed into reverse for just a second but it was long enough that I think I heard the tires loose traction on the wet road. If the roads weren't wet it would have chirpped the tires.I'm hoping that I didn't shorten it's life too much. I guess I'm looking for a little peace of mind. Any thoughts?
Old 11-02-2006, 12:27 PM
I've done it more times than I care to admit from speeds of 20 - 60 but I quickly jerked it back into drive or neutral. I didn't have any immediate detrimental effects and continued driving the vehicles a few years before I sold them. One was a Mustang and one was a Ford F100. Both had C4's.
Old 11-02-2006, 12:32 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Reverse lockout?
Old 11-02-2006, 01:26 PM
Accidently went into [email protected] 20mph!!
What type of vehicle?Also what year and engine size.
Old 11-02-2006, 04:18 PM
73oldsman's Avatar
Oops! I did that once in my 68 Nova with a 6 banger and automatic. Made the tires chirp too and scared the hell out of me. I put it back into drive right away and kept on driving. I never had any problems with the tranny. Pulled the tranny pan and swapped out the filter and fluid later. Nothing unusual was seen.
Old 11-02-2006, 06:45 PM
Sorry I forgot to put this info in: Car is 1999 linc. continental, 4.6 with AX4N I think. Car is front wheel drive. The " revese lockout" it's a floor shift and to go to neutral I have to push a button and I went to far and into reverse. All the other floor shifts I've you can just push it into neutral, kind of weird.
Old 11-02-2006, 08:19 PM
Accidently went into reverse @ 20mph!!
Wow! that will be expensive if it did hurt it,but I doubt it did.
The fact that it was overheating may have a more detrimental effect.
I suggest you change fluid as soon as overheating problem is corrected.
I hope it works out well for you.
Old 11-03-2006, 07:03 AM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
Back in '64 my little sister pushed the lever on my dad's Powerrglide into reverse on the freeway.
He drove that car another 8 years and 100,000 miles.
Old 11-03-2006, 02:10 PM
Did that once going down the track in my 71 chevelle...felt like the car went sideways and about 5 feet in the air, (wasn't that bad really). No damage though.
Old 11-04-2006, 07:57 AM
Update; Solved the overheat problem, been driving it and there doesn't seen to be any immediate damage to transmission. Thanks for the responses I'm feeling alot better.
Old 11-05-2006, 10:51 AM
i did that in my mom's 98 ram1500. it was running really rough when i wasnt on the gas, almost trying to die. down hills id find neutral so i could be on the gas still. when i hit reverse the back tires got loose and i quickly found nuetral...
in my 89 camaro 700r4, i was doing about 15-ish and hit reverse. my lockout didnt work. however the tires didnt slip... instead the car died and wouldnt start. come to find out i reverse the engine and it required lots of cranking and recharging. ran fine after that till just recently.
Old 11-05-2006, 11:58 AM
Y2K Y2K is offline
I did it in a '64 Comet 289/C4 at 60 mph when I ran out of gas and tried to get netural to coast to the gas station less than a mile away.
Broke both motor mounts and tore the radiator hoses off,and also tore up the exhaust pipes and tranny cooling lines.
I never try for netural with an auto trans while moving anymore.
Old 11-05-2006, 07:04 PM
jray's Avatar
Always remember...that R does not stand for RACE!!
Old 11-05-2006, 07:51 PM
oops
as long as none of the mounts were damaged and it still shifts fine you should be fine however i would take the pan off and look for any sign of major damage but if it still drives fine then i wouldnt worrie about it
Old 11-05-2006, 11:16 PM
Bare Knuckles Champ
Last journal entry: Made a wrench...
You did it on accident?!!?
Sad to admit, but I used to do this all the time for kicks. '71 F150 with C6, column shift. I'd do it at about 45 & floor it. Makes huge 'J' hooks where the rubber makes a long straight line, then stops & backs off to one side or the other, usually to the right due to road slope here in the mountains.
You gotta understand I was a teenager who spent all my spare time & $$ on cars & abusing them. Tiny town with no traffic, and this is what we did at all hours of the night. Worked too, I didn't have a drink or any other vice until after I joined the Corps.
Oh yeah. After months of this, it became very difficult to find Drive on the column shifter. That's all the damage that was done. I guess it really relies on the strength of the sprag assembly. Guess that C6 had a great one. Along with a tight posi & a warmed over 360.
Save your flames. I'm not saying it was smart, just fun. And relevant to the conversation at hand.
Derm (just back from SEMA)
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
Making a reverse shape in sheet metal John Kelly Body - Exterior 4 12-16-2005 08:24 PM
140 mph over the speed limit! dinger Hotrodders' Lounge 38 08-07-2005 04:23 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Update on 205 mph speeding ticket dinger Hotrodders' Lounge 14 09-27-2004 11:23 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
