Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Adjustable Steering Column?
Old 06-25-2015, 10:17 AM
416Ford's Avatar
416Ford 416Ford is offline
May be a collapsible steering column and the bottom shaft has slid out. Outer column needs to be mounted in it's proper place and then adjust the inner sleeve to match up to the coupler/rag joint.
Can you post a picture on the lower column under the hood.
