Adjusting doors - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2014, 01:28 PM
Adjusting doors
Help !
trying to adjust the passenger door on a 32 ford pick-up. heres the problem/
the front of the door fits great, top and bottom. The rear of the door is 3/8 " ope on top, but 1" open on the bottom is there a way to bring the bottom in closer ?
Thanks in advance .
Old 05-18-2014, 01:50 PM
how are the hinges? good condition?
Old 05-18-2014, 02:11 PM
Originally Posted by bonos40 View Post
Help !
Thanks in advance .
Are you saying OUT as in if you simply opened the door an inch or do you mean the "gap" from the door to the cab is an inch? You really need to post photos to get a good idea.
But if it's "open" as in the door isn't closed all the way at the bottom it is very likely the door is twisted.
Old 05-19-2014, 04:42 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
Or somebody installed a 1/4 on wrong (with the door off)
The Following User Says Thank You to deadbodyman For This Useful Post:
MARTINSR (05-19-2014)
Old 05-19-2014, 07:16 AM
EXACTLY DBM, we need more info here, a LOT more info!
Old 05-19-2014, 08:21 AM
Jallopy's Avatar
The door is twisted.
To fix put a block of wood with a rag around it to protect the paint at the top of the door skin height .
The wood will keep the door open about 2 inches now push the bottom of the door in to take the twist out .
You may have to do this a few times to get the gap correct.
Photos would also help... if this fails to get the door lined up.
Old 05-19-2014, 01:07 PM
Body shimming can also cause the cab to twist and make it appear that the door is at fault. If it is a shim problem the drivers door should have the opposite problem.
We really could use some pictures as Brian said.
John
adjusting the hood and doors on my 1949 chevy pickup tbrown8338 Body - Exterior 8 12-04-2011 11:46 PM
adjusting rear barn doors '51 Suburban aldwaup Body - Exterior 4 03-28-2007 08:57 AM
adjusting my doors on my 34 Chevy 3 window coupe robbie34chevy Body - Exterior 6 04-17-2006 12:15 PM
Adjusting Model A Doors western star Hotrodding Basics 5 03-12-2005 08:40 AM
'54 Chevy Pickup - Adjusting the Doors horvath Body - Exterior 26 05-15-2003 04:47 PM
