Advice removing door hinges - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2018, 12:47 PM
AJPSK's Avatar
Cookie
Hell!
I have a 41 Chevy coupe. I am working on the car trying to remove the front door hinges. Which after all these years are rusted. The center bolts are counter sunk bask in to the hinge box. Very difficult to get at. Any ideas or help appreciated?
Old 11-16-2018, 02:05 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
A photo would help, are they hex head, allen head, phillips head, etc?
Semper Fi
Old 11-16-2018, 05:24 PM
39 master's Avatar
Hinges
I've had problems with hinge removal over the years and it's not easy. Soak with penetrating oil over several days and use a hand impact driver to back them out. Most are phillips but make sure you have a bit that fits tight. If all else fails about a quarter stick usually works!
Old 11-16-2018, 06:09 PM
Originally Posted by AJPSK View Post
Hell!
I ran into the same problem working on my 52 Plymouth. If you can get a torch with a small tip. Heat the nut red hot, and let it cool. Just before it cools completely, hit it with some penetrating oil. It should come out. If no torch, even a propane torch will do some good. Like someone else mentioned use a impact screw driver. Just don't burn up your truck. stan
Old 11-16-2018, 10:27 PM
'49 Ford Coupe's Avatar
1949 Ford Coupe RESURRECTION
The first two pictures of this gallery will help
https://49fordcoupe.smugmug.com/The-Doors/
The Following User Says Thank You to '49 Ford Coupe For This Useful Post:
de_greaser (11-20-2018)
Old 11-17-2018, 07:39 AM
Bash the heck out of it with a impact screwdriver.
When that does not work you can try this proven trick.
WEAR EYE PROTECTION AND LONG SLEEVES WHEN DOING THIS.
Take your grinder and cutoff wheel then cut just the hinge so that it cuts the upper 2 bolts in half.
Then cut the hinge so the lower 2 bolts are cut in half.
You need to be careful here to just cut the hinge. You don't need to cut completely through but over 1/2 way. Your cutting up to the bolt not into the bolt.
Now weld a rod to the top part of the hinge then pull down on it and it will start to bend. Welding the rod saves the body instead of using a chisel to pry it up the hinge scratching the body. Once up hit it back up gently and pull down repeating until it breaks.
Do the same with the bottom until it breaks.
Now cut a mark in the middle between the upper and lower rows. This one you need to be completely through on. Now take a chisel and hit the upper part of the hinge down over the lower until it clangs against the shop floor. Then hit the lower up and your left with the 4 bolts exposed.
I grind these till the heads are square then hammer on a 8 socket on them after hitting them with pentrating oil and heating the area around them. They come right off.
Now clean your threads and replace the Phillips with countersunk hex screws 4 or larger so you can use a common socket to get them off next time.
Old 11-17-2018, 08:14 AM
55 Tony's Avatar
Torch it. If you don't have a real torch, go get a MAPP gas torch and bottle of MAPP gas. Don't use the MAPP with a propane torch, the MAPP one will put out a hellova lot more heat. Cycle it hot and cold, cold water in a squirt bottle will help. Go to Horror Freight and buy a big screwdriver to fit the screws and cut the handle so you can hammer on it metal to metal. Heat, hammer, cool in whatever order you feel like. Try to get the heads as red as you can but it will be hard with the little torch. After every few hot, cold, hammer cycles try to turn it. Be sure to have a screwdriver that fits the head perfect.
Old 11-17-2018, 10:37 AM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
I dislike using fire on cars and my hand impact driver has been borrowed and beaten into a non-functioning state. What remains is a fairly wimpy old 1/2" impact with a nice smooth trigger and an adjustment knob. I turn it all the way down, really lean into it to keep the bit seated, and feather the trigger oh so carefully to bump the big old countersunk phillips heads out using the bit and adapter from the hand impact driver set. It has worked remarkably well, even without heat or penetrant. Knowing what access is like could help in culling these suggestions. I am unfamiliar with that body style.
Where can i buy suicide door hinges for my 53 chevy truck? engineart Body - Exterior 10 03-06-2006 03:02 PM
repairing door hinges nd500 Body - Exterior 2 05-23-2003 08:45 PM
building door hinges spankthru Body - Exterior 1 05-12-2003 08:05 AM
LOOKING FOR 55 - 57 Belair or 210 Door Hinges BATMAN Body - Exterior 0 03-20-2003 07:14 PM
37 plymoth 4 door project/trunk hinges slider in wa Body - Exterior 8 11-08-2002 06:23 PM
