Aftermarket Speedometer for 48 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2018, 06:36 PM
autorepairguy's Avatar
Last journal entry: Frame sandblasted,primer
I have been researching what speedometer to use in my 48 Fleetline.I would like to use a large diameter speedometer like the original bu I can't help but notice that the vast majority of builds people are doing on this year (these years) are using a much smaller diameter gauge(3 5/8).I'm wondering if theres a reason other than most people want a smaller gauge??.A 5" gauge is available through some online vendors.Any ideas?
Old 12-12-2018, 04:24 AM
It is a more common size giving you more options of styles and brands both now and in the future.
Old 12-12-2018, 09:28 AM
39 master's Avatar
Speedo
Many reasons builders are using smaller dials, room being just one. Smaller dashes on the older cars just can't handle a large speedo, tach and 4 other gauges but one solution is to buy the "all in one" larger gauges with everything in one large gauge. Every time you slide behind the wheel the gauges are in your face so picking the ones you are happy with is very important. As a side note I recommend an electronic speedo because wires are easier to run than a cable, calibration is just a push of the button and when tire size, gear change or trans change happens recalibration is just a push of the button.
Dumb question regarding aftermarket speedometer 47 Ford Coupe Delux Hotrodding Basics 12 11-30-2018 08:36 PM
700r4 electronic speedometer conversion to mechanical speedometer [email protected] Transmission - Rearend 9 07-12-2012 12:30 AM
Aftermarket Speedometer! PeterFred General Rodding Tech 6 11-17-2010 01:36 PM
Aftermarket Speedometer odieboy General Rodding Tech 1 11-30-2009 04:18 PM
Aftermarket Speedometer WakBordr7387 General Rodding Tech 9 07-12-2005 02:04 PM
