Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - air compressor
Thread: air compressor
Old 05-04-2019, 05:57 AM
55 Tony's Avatar
55 Tony 55 Tony is offline
Originally Posted by mitmaks View Post
it worked fine but would plug up valve on compressor and it would leak out all the air. There is some oil on top of the piston.
If it was leaking out after stopping, it was most likely either the check valve where the air goes into the tank, or the unloader valve that takes the pressure off the pump after it stops. (that truck air brake sound when it stops)
Young enough to learn ... too old to remember.
