air compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2019, 08:32 PM
mitmaks's Avatar
Last journal entry: Grille
air compressor
I have older model Kobalt 60 gal compressor and Ive rebuilt head, put in new reed valves. Compressor runs and builds up pressure but very slow and smells oily. What could be culprit?
Old 04-28-2019, 05:57 AM
55 Tony's Avatar
How did it work before the head job? (NPI) Might need rings. What kind of oil are you using, or is it one of those oil less ones?
Old 04-28-2019, 09:03 PM
mitmaks's Avatar
Im using regular compressor oil. When I took head off of it there was a little bit of oil on top of the piston.
Old 04-29-2019, 07:10 AM
55 Tony's Avatar
How did it work before the new valves? Same thing or is this new? I've heard from old timers that their compressor never worked as good after cleaning the reed valves. I think they get a little gummy and seal better. I'd run the hell out of it and see if it gets broken in. Otherwise plan on new rings and honing the cylinders.
Mine is almost 50 years old and going strong. Although I don't know it's history, I've only had it about 7 or 8 years. It's a Saylor Beall.
Old 05-03-2019, 08:14 PM
mitmaks's Avatar
it worked fine but would plug up valve on compressor and it would leak out all the air. There is some oil on top of the piston.
Old 05-04-2019, 04:57 AM
55 Tony's Avatar
If it was leaking out after stopping, it was most likely either the check valve where the air goes into the tank, or the unloader valve that takes the pressure off the pump after it stops. (that truck air brake sound when it stops)
Small Temporary Air Compressor ChevelleSS_LS6 Garage - Tools 3 01-06-2012 06:33 PM
Air Compressor, oxy / ace, propane outdoors - Info / Issues ctkid343w Garage - Tools 12 01-29-2011 09:48 AM
Carb emulsion question bfitz241 Engine 7 01-15-2011 11:00 AM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
