Alternator issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2015, 02:56 AM
89silverado454's Avatar
snowslinger
Alternator issue
1984 corvette crossfire 350
Alternator stopped charging the bat.
Checked voltage at back of alternator, shows 30 volts.. Not good.
Brand new alternator
What could cause this?
Old 09-04-2015, 06:52 AM
delawarebill's Avatar
alt
i'll assume u don't have a separate voltage reg then.. diodes can die giving wacko readings.. what was the voltage at the battery when all this was going on ??
Old 09-04-2015, 08:45 AM
snowslinger
so you think the alternator is bad.
hope I can find a new one, bought this one yesterday. tried 5 different parts stores and this was the only one I found in the state so far!
Old 09-04-2015, 10:14 AM
alt
does it have a separate voltage reg ??? fire it up and measure the volts AT the battery. voltage at battery should be right around 14v. if reading 12v and u have a alt that has a built in reg then yes it's time to replace it.
Old 09-04-2015, 04:30 PM
snowslinger
I have no idea if this thing has a separate voltage regulator.
Tracked down a alternator in anchorage. Put it in the vet, checked the voltage at back of the alt this ones showing 54-55 volts.
Old 09-04-2015, 05:32 PM
snowslinger
Figured it out. Disconnected the bat wire from the alt, no power.
So either the wire is broke (unlikely) or a fusable link is toast (probably)
Used a jumper cable from the pos on the battery to the pos on the alt, 14.2-14.3 volts at the alt & battery.
Old 09-04-2015, 05:50 PM
alt
perfect !!!!!!! that's the number i wanted.. u did good.. use a VOM meter to ck the wire and link.. see piece of cake...
now i just ask that u keep the snow up there.. that's gonna be harder..
Old 09-04-2015, 05:54 PM
snowslinger
I'll turn a wrench all day... But I absolutely hate wiring
Snow... I'm not ready! Iv only put about 20 miles on the vette sense I got it. Work out of town on a 2weeks on/2weeks off rotation. I probably only have about 4 weeks of time home to get this thing running good & enjoy it before I park it for the winter.
alternator issue winksr Electrical 3 11-24-2014 04:37 AM
alternator wiring issue. 56dodge Electrical 4 08-19-2010 06:02 PM
Alternator issue? 84TA406 Electrical 4 07-04-2010 09:52 PM
Alternator/regulator issue eastboundanddown Electrical 4 01-18-2009 09:09 AM
RE: Alternator/Regulator issue eastboundanddown Electrical 0 01-15-2009 03:32 PM
