Another Newbie Painter - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2008, 11:13 AM
I am repainting a car with Acrylic Metallic Enamel. After apply several coats, I let the paint dry overnight, smoothed it with steel wool & applied a final coat. After a few minutes, the new paint began to wrinkle severely, looking like a dry lake bed. What in the world has happened here ? I have little painting experience & known with metallic acrylic. Do I need more dry time or is additional sanding & spaying not allowed ???
Old 10-17-2008, 12:44 PM
cyclopsblown34's Avatar
Colorsanding painter
I think you might have applied the paint too wet when you scuffed and shot it again. My other guess is the first coats of paint might need to dry longer before applying more paint.
Old 10-17-2008, 03:22 PM
Thanks
At the moment, the only option I see is to let the paint dry for a few more days & try it again. I have my doubts, as I repainted a small piece of trim after two days of drying time & the same thing occurred. Another possibility I thought might be the cause is that, after scuffing, I wiped the area clean with a cloth dampened with the acrylic enamel reducer I use to thin the paint. Could that have softened the paint enough to cause this ? The thinner evaporated immediately, so I didn't give it another thought.
Thanks for your input.
Old 10-17-2008, 03:36 PM
I'd say to let it dry for a few weeks, preferably in the sun before attempting to recoat it.
Old 10-17-2008, 03:51 PM
Hmmmmmm
I could take several guesses BUT I think it would be better in the long run for you to make sure you have read ALL the tech info sheets on the products you are using. In there somewhere there will be something that talks about "recoat time".
Every product.....not just every manufacturer, but every product has it's own unique chemistry, and the time you allow between coats "flash time" is more critical on some products than others.
In general you can recoat either within the initial wet stage after allowing for the specified "flash off" of solvents between wet coats.
After that....you pretty much have to wait till the stuff dries, or cures, before you can add any other coats because the new solvents reach into the first coats and draw them up causing the crinkles you described.
It's probably a chemical shock thing.
I also think that if this paint job is important to you, then maybe you might consider stripping this damaged stuff and begin from the beginning.
I think the foundation or base of this paint job has been compromised, and probably will not last very long before it fails.
I have always been one to rush into something without reading the directions very well....then the whole project goes [email protected]#$%!!!!!!
It's taken me many years to finally learn about the saying "never time to do it right, but always time to do it OVER"
Old 10-17-2008, 04:14 PM
Good Advice
The "re-coat time" on the paint is "within 48 hours" or "after one week". Thought I was within the 48 hour span, but maybe not. Can't find anything on the reducer. I did have to increase the reducer to paint ratio from 4-1 to 3-1 to get a smoother finish. Perhaps the additional reducer reduced the re-coat time? Guess I'll give it at least a week before trying again. Will definitely heed your advice on starting over on the two pieces that are wrinkled.
Thanks, very much, for you advice.
Problems with a painter Bad Rat Body - Exterior 26 04-05-2006 12:13 PM
Too many Newbie Questions Shakey Body - Exterior 3 05-08-2005 07:52 PM
newbie painter Niapym Body - Exterior 10 08-22-2004 11:01 AM
Help Kosmao96 Body - Exterior 12 06-28-2004 03:29 PM
Flame Painter For My Cruiser prpro22940 Body - Exterior 9 07-27-2003 02:42 PM
