Another "what carb" question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2004, 09:29 AM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
327 Chevy, .030 over, 12.73:1, 292/302, Lift .488/.510, Single 4 tunnel ram.
1985 Firebird, 3000 converter, 4.11 gears.
Do you think a 700 mech. secondary double pumper is too small?
How about if I dropped compression to 10.5:1?
Old 09-21-2004, 09:56 AM
700 wont be to small.What max RPM do you plan to see with it ?
Old 09-21-2004, 10:00 AM
Lonestar's Avatar
She is built to withstand 8,000, but don't really want to go farther than 7,000-7,500.
I have been having trouble tuning this thing, and was thinking maybe the 700 was too small eben though it figures out ok in the calcs.
Old 09-21-2004, 10:03 AM
Id ditch the tunnel ram & use a Victor Jr or team G
Old 09-21-2004, 11:14 AM
Lonestar's Avatar
Ditching the tunnel ram is not an option. I have my reasons.
Old 09-21-2004, 12:11 PM
willys36@aol.com's Avatar
Wiki Edits: 21
I built my own tunnel ram about 1966 or so. May have been the first one ever built?!? Anyway, it had NO bottom end which makes total sense 'cause the velocity signal is totally killed in the shoe-box section. I'm afraid you are stuck with great +3000 potential a the expense of way less than acceptable bottom end performance. Those manifolds are intended solely for top end operation with NO bottom end. So is the double pumper. Only suggestions I can make are 1) consider getting a vacuum secondary carb and/or significantly reduce the plenum volume of the manifold with Devcon Liquid Steel.
Old 09-21-2004, 12:20 PM
Lonestar's Avatar
I am not interested in bottom end, I just want the thing to scream (there is sanity to my madness).
I can raise my idle to around 1500 or so, which takes care of the instant fouling of my plugs at idle.
The question is, do you all think the 700 is the right size carburetor for my "current" set-up?
Old 09-21-2004, 12:46 PM
If all you care about is top end...sure, the 700 should work. However, I dont think youll ever get that combo to run great across the board.
Old 09-21-2004, 12:53 PM
Lonestar's Avatar
Thanks, and yes, I don't care about anything but WOT. The car is not street legal.
I was just wondering if maybe I should go to a bigger carb.
Old 09-21-2004, 01:55 PM
Wiki Edits: 21
Then you are set up perfectly. Post your time slips so we can drool!
Old 09-21-2004, 02:31 PM
Lonestar's Avatar
Just out of curiosity, what kind of times do you think I could get out of this setup (1/4).
The car is gutted and weighs about 2900 with me in it.
9" Ford 4 link with 17" MT's (DOT)
Old 09-21-2004, 02:42 PM
dont really know enough about the entire package, but Id say mid 11s with proper gearing
just hard to say without more info, dont know what heads you have, if that cam is hyd., solid, hyd. roller, roller, duration @ .050, lobe seperation, what tranny, tire diameter et. etc.
Old 09-21-2004, 02:50 PM
Lonestar's Avatar
I understand what you're saying. I know what times the engine ran in my S-10, so I have an idea of what to expect out of this car.
I had just been pondering the carb size.
If the track over here ever opens for 1/4's again, I'll post slips. They cut it down to 1/8's because the end of the track was in poor shape.
Thanks for the replies.
