Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Anyone put a 302/5.0 into a 57 Fairlane?
Old 10-31-2005, 05:04 PM
woodz428's Avatar
woodz428 woodz428 is offline
Troll Hunter
Not to start a debate in this thread but The Windsor is much easier to fit into tight compartments than a Cleveland....MUCH easier. The exhausts fit closer to the engine on a W because of the port angle, plus they are inward of the block edge where the C ports are AT the block edge. Look at any Mustang that has a W and then one with a C and you'll see that the Windsor has much more room. If you're in the area stop by and I'll show you one of each.
