Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - anyone use weld tabs for multi pull on a standard stud gun?
Old 10-17-2016, 08:50 PM
tech69 tech69 is offline
put up or shut up
Originally Posted by idrivejunk View Post
If you need to weld washers and use a hook, or tabs and clamp, for a heavier pull, use the MIG. For light pulls use wiggle wire. I don't understand why you bash the country you live in so much. Did you look at Spitznagel?
has nothing to do with bashing the country. In other countries the techs can fix more cause they don't replace parts as much. In metal shaping guys are better in other countries too. Not bashing the country, just stating a fact.
