Asphalt paving in below-freezing temps? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2007, 08:21 PM
Z-Money Pit's Avatar
I have finally decided to have my driveway paved with asphalt. It is currently covered with a dirt/gravel mix. Is there any concern with having this done if the temperature is below freezing? Will this effect the longevity and quality of the paving?
Old 01-21-2007, 08:32 PM
tfeverfred's Avatar
Last journal entry: Black Dahlia pics
I've read that concrete won't set correctly in fridged conditions. I'm not sure about asphalt. Why can't you wait till the weather is better?
Old 01-21-2007, 08:38 PM
tfeverfred's Avatar
I found a link. It mentions that it can be done, but in a specific way.
http://www.cts.umn.edu/research/proj....pl?id=1994029
Old 01-21-2007, 08:39 PM
I could wait until Spring if the asphalt is effected by the cold temps. If the temperature does not have an effect on asphalt then I will have it done now.
I would love to do concrete but my driveway is way too big and it would cost a fortune!
Old 01-21-2007, 10:48 PM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
The city where I live wont pave if the temp is under 50 deg. Last year they repaved at 50 deg and the street came up with holes in it when the weather warmed up. This was repave project not new construction.
Old 01-22-2007, 06:42 AM
Last journal entry: frame build
You could do it if you could find a plant still making asphalt in winter. All you would have to do is blanket the site and get the ground temp over 50 dg and keep it there for about three days for the asphalt to set. Probably have to house it to so It could be properly laid and rolled before it cools. Of course, the site prep would be a little shaky. You could maybe ahh forget it. You aren't going to find anyone that will fire their plant for 20 yards of asphalt till spring. and if you did, your name says it all.
Old 01-22-2007, 07:36 AM
454rattler's Avatar
NEVER satisfied !
Are the prices for asphalt drives based on square feet or something else? I know its a dumb question but........
What are the prices in places other guys live ?
Old 01-22-2007, 11:41 AM
temp
50 degrees or the more the better--wait until summer !!!
Old 01-22-2007, 11:48 AM
Henry Highrise's Avatar
Lost in the 60's
Last wiki edit: Removing stuck fasteners
Wiki Edits: 4
Wait untill Summer....the hotter and drier the better. If you did it now you would be wasteing your money as it would not hold up.
Old 01-22-2007, 01:20 PM
Thanks everyone for your replies. I will be waiting until Spring or Summer to have it done.
Old 01-22-2007, 06:57 PM
Asphalt prices are usually based on aplaced yard. A small quantity job is going to be a lot more expensive than a large job because it takes all the same equipment to do it and most of the time each piece will be setting waiting for another piece to get out of the way. You may find that concrete is competitive on a driveway project under 2 hundred feet.
Old 01-22-2007, 07:16 PM
454rattler's Avatar
NEVER satisfied !
Very useful information here. Using HR.Com is better than picking up the phone. We can get more than one opinion. Thanks, guys !! 454 Rattler
Old 01-23-2007, 03:15 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Yep. You had better wait. All crews quit around November around here until it gets back up to at least 50 degrees and stays there.
Kevin
Are todays engine temps ok for older engines old-bill-t Engine 26 08-01-2011 02:08 PM
Minimum temps for spraying Omni birdguy Body - Exterior 10 10-24-2006 08:01 AM
Carb - Parts cleaner Freezing skeeveman Garage - Tools 1 02-13-2006 06:05 AM
What are the problems associated with using alum heads below freezing? Dubz Engine 9 02-16-2005 03:57 PM
Pyrometer temps ? roys63 Engine 8 06-04-2003 06:00 PM
