Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - axel travel question
Old 12-09-2018, 02:30 PM
Captn_Jim Captn_Jim is offline
Originally Posted by ericnova72 View Post
Have you also accounted for how far the weight of the bed is going to make things settle after it is installed??
I am counting in about 1/2" lowering with the new bed I am putting on.
" If the point is right there at the back of the fuel tank/crossmember that we can see in the picture, the driveshaft at that point is only going to move about 1/2 or a little less of that 4-1/2" axle travel, so I think you'd be good?? "
The 4 1/2" travel is based on the angle from center axel to transmission and the clearance that I have at the point directly under the bracket. Actual clearance at that point is more like 1 1/2".
