Bad news - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-26-2020, 05:33 PM
Robogear is the email.
Is it the rocker arm that is hitting the guide plate?
  #17 (permalink)
Old 07-26-2020, 05:55 PM
Here's a photo removed one push rod says comp cams magnum 7372
ID:	457597   Click image for larger version
ID:	457599   Click image for larger version
ID:	457601   Click image for larger version
  #18 (permalink)
Old 07-26-2020, 06:08 PM
Bushrod is cutting into guide plate
  #19 (permalink)
Old 07-26-2020, 06:09 PM
2001Blazer4x4's Avatar
Redneck Professional
Does this have a flat cam lobe or two?
Sent from my moto g power using Tapatalk
  #20 (permalink)
Old 07-26-2020, 06:15 PM
ericnova72's Avatar
More for Less Racer
Look at the Email name on the invoice....I think Rip VW has nailed it, looks like the same Robo guy in Washington State who we know has built junk in the past. He suckers a few guys, gets a bad rep, folds his tent and resurfaces under a new name.
One was Robo Racing/James Roby in the past, just do a search here at Hotrodders and you won't find anything good.
https://www.ripoffreport.com/reports...hingto-1380782
  #21 (permalink)
Old 07-26-2020, 06:18 PM
ericnova72's Avatar
More for Less Racer
I don't see it cutting into it...I see the black oxide coating rubbed off on a hardened pushrod, that would be normal to see.
Is the guideplate metal actually worn away where the pushrod is touching it?? That would be a problem....just black oxide rubbed of either part is normal.
  #22 (permalink)
Old 07-26-2020, 06:23 PM
johnsongrass1's Avatar
Race it, Don't rice it!
All one piece push rods are likely hardened. Lets say I've never seen one that not.
That rubbing in the picture is normal. It rubbing the guide to keep the rocker where it's supposed to be.
  #23 (permalink)
Old 07-26-2020, 06:32 PM
So just by this photo no way of knowing if I have the right pushrod?
  #24 (permalink)
Old 07-26-2020, 06:49 PM
True story. That's why you were advised to follow the video. Then you know...for sure.
  #25 (permalink)
Old 07-26-2020, 06:52 PM
ericnova72's Avatar
More for Less Racer
Nope, not by just a photo like that. Impossible to tell just by looking at something like that because nobody's eye is calibrated enough to tell.
That's why the two videos with the proper methods were posted.
  #26 (permalink)
Old 07-26-2020, 07:06 PM
Not sure if you recall my rocker nuts Allen's being deeper pulled one of those pushrods and no name here is a photo
ID:	457607   Click image for larger version
  #27 (permalink)
Old 07-26-2020, 07:34 PM
ericnova72's Avatar
More for Less Racer
Check it's length against one of the others what has a name on the side of it.
I'm going to bet the length is different.
This is why I said over a week ago in your rocker arm thread that you need to tear some of it apart and investigate.....I even mentioned the possibility that someone has thrown various sets and sizes of parts together....
  #28 (permalink)
64nailhead's Avatar
That is not the same type pushrod that you had in the previous picture. That is a stock style pushrod that cannot be run with guideplates.
I strongly recommend following Scott Foxwell's video and getting the correct length pushrod. And hope the cam is still OK.
Johnson mentioned that there is no need to pull the intake, but at this point I'd be yanking this thing apart after completing a leak down test.
But if you're not wanting to do that, then at least figure out if the stock style pushrod is longer or shorter than the others and report back.
  #29 (permalink)
Old 07-26-2020, 07:50 PM
Posting a photo that has cylinder 8 push rod at top cylinder 2 push rod in middle and a stock Goodwrench 350 motor push rod at bottom. Talk to me guys. Want to fly out to Cali haha
ID:	457611   Click image for larger version
ID:	457613   Click image for larger version
  #30 (permalink)
Old 07-26-2020, 07:52 PM
Cridder's Avatar
Vd=0.7854B2S, CR=Vd+Vc/Vc
Last journal entry: 310 Small Block Chevy
Robo engines warning !
Originally Posted by Rip VW View Post
The guy in Spokane I was referencing to ran a shop called "Robo Racing" The guys last name was Robi or robo or something like that. Anyway I would not trust anything he builds.
The email address on that invoice is "robogear", looks like you found your guy again.
Small world sometimes eh !
