Base, flames, clear? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 05-17-2016, 09:26 AM
Hi,
I have painted my 23 T-Bucket 2 weeks ago. No clear yet. I have scuffed the paint as advised by Summit Racing (whose urethane paint I am using) due to the down time.
I will be laying down one coat of clear prior to some flames and some pinstriping, then 2 coats clear over that. My question is:
I have scuffed (sanded) the paint to allow for adhesion oif the clear but should I do mthe same with the flames or can I clear over them without sanding? I won't be clearing right away.
Thanks.
Old 05-17-2016, 03:28 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
2 coats of that clear will not give you enough to cut and buff or get rid of flame edges. you'll burn through sanding .
Old 05-18-2016, 05:24 AM
astroracer's Avatar
Last wiki edit: Crankshaft Coalition Wiki
I would just spray the flames over the base and THEN clear. Bury the artwork very well, like shine suggested, to give you material to sand down the edges of the flames. If you keep the flame coverage to a minimum the edge should be minimal anyway.
I did this on my '95 pickup and it worked very well.
Mark
Old 05-18-2016, 07:41 AM
33Willys77's Avatar
If you don't need to put more color on (hopefully it is a solid color), you can just put the flames on and then clear.
My preferred process: 1) put the main color on, then 2 coats of clear. 2) sand everything, layout flames and paint, then 3 coats of clear. 3) sand it all, most of the flame edge will be gone, but usually not totally, but ok at this point. 4) pinstripe/airbrush and 3 more coats.
This process is not always used as most people wont pay for the work, sometimes I pinstripe after laying out the flames and then 3-4 coats of clear to try to bury it all.
sanding clear then repaint with base clear agian questions tiptopss Body - Exterior 8 04-20-2010 07:09 AM
Flames without the clear coat?? Yes or No Jim Weeks Body - Exterior 4 04-13-2009 05:21 PM
low priced spray gun/detail gun for primer/base/clear and ghost flames jrmy_1 Body - Exterior 15 06-08-2008 06:38 AM
Mix Clear with Final Base coat prior to clear x711 Body - Exterior 10 04-08-2006 07:55 AM
orange base with silver ghost flames chad40x Body - Exterior 0 06-27-2003 12:54 PM
