Behind the dash brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2019, 04:47 PM
Anyone make your own brackets to go 90 or 180 behind the dash from scratch?
Looking for linkage setups, pedal designs, venting, and resivior ideas for clutch and brakes.
Old 03-23-2019, 05:50 PM
dusterdude3404's Avatar
If you want 90 degree linkage,try to find a dodge van from the 70's,they had 90 degree linkage.
Sent from my LG-US601 using Tapatalk
The Following User Says Thank You to dusterdude3404 For This Useful Post:
cerial (03-25-2019)
Old 03-24-2019, 06:36 AM
https://www.speedwaymotors.com/Unive...bly,60736.html
Click above and buy one of these. Or if you're an engineer and can get all the moment arms the right length and in perfect alignment with no binding the first time and you're a first class welder, make one. If not buy one and save your and your passengers lives. There's still going to be some fabrication to mount the 90 degree unit in your car. Make sure it's solid and comfortable to use. Do it right the first time.
The Following 2 Users Say Thank You to '48 Austin For This Useful Post:
cerial (03-25-2019), kbuhagiar (04-01-2019)
Old 03-24-2019, 01:13 PM
Yes thats how most of them do it. Basically looking at doing that in cooper going 90 with a rod going to the passenger side. Clutch is just going to be a 7/1 with a cable going to clutch pulling the fork back.
I have a 02 hydroboost with pedal(i took a saw zaw to the firewall and pulled it as a unit) so I have the pedal to maintain the proper ratio from there it is just a 1/1 bellcrank and securely mounting the hydroboost.
I am going to have most of the dash and mechanisms (brakes,shifters, etc) exposed so was looking for people that may have went that route making the exposed items look nice.
But yes just using the bellcrank/pedal mounts with 1" bolt and some 1/4" copper brackets will probally look good enough once polished.
Only thing left on the firewall will be the wiper motor which I am alright just covering.
Old 03-25-2019, 05:26 PM
You might look here Reverse 90 Under Dash : Kugel Komponents, Quality Komponents Since 1969 they also have a 180 degree setup that looks pretty clean.
The Following User Says Thank You to enjenjo For This Useful Post:
cerial (03-25-2019)
Old 03-25-2019, 07:16 PM
ogre's Avatar
the 'Duracell Project'
i mounted the hydroboost under the floor in my 58 truk
kept the firewall clean and spotless
The Following User Says Thank You to ogre For This Useful Post:
cerial (03-25-2019)
Old 03-25-2019, 11:43 PM
Yes been drooling over there stuff for years. This build is a collection of things I wanted to do. But just caved on and went the traditional route with other rides.
Cut that 90 with 180 clutch in half and you have what I am building.
Building a entire floor and most of the firewall on this enforcing what little rusted shell I have to work with before removing the dash. I will have a removable center section(think van) and non adjustable bucket seats which are part of the floor.
The floor will go back to a flat style (another reason for removing the saddle tanks) and I am going to run "boat" style seats where the seat bottom can be pulled up for two 10" high x24x24 under seat storage areas.
The 2 batteries are going behind the drivers side of the cab next to and above the bottom of the frame rail on the outside. I did flirt with mounting the Master on the inside of that frame rail. This does keep the pedals stupid simple and dash/firewall ultra clean.
Only downside of this is that is that this is not a show truck. I want a flat belly with this and to slap that belly/bottom of the frame against logs etc with some light mud.
That being said we are talking about a skid plate there and the more I think about it I could easily mount a remote resivior in front of the batteries tight to the back of the cab for easy filling.
The more I think about through the floor pedals the more I like it. Running fender well exhaust so I could run the hydro boost/brake lines right up the inside of the frame rail without issue and the clutch pedal becomes much simpler also.
Through the floor pedals sounds like it wins on many occasions. Cleaner firewall, dash, less linkage, and puts everything outside. Only downside is that it is outside and will be coated in mud, snow, ice but it is a sealed system so it should be fine. Will look at popping that reservoir off the master and mounting it against the cab above the batteries with a leather cover for easier filling and keeping it from possibly being submerged.
Going with through the floor pedals. Thought they would be more complicated then they are. But the more I look at them it makes tons more sense.
Thank you.
Old 03-26-2019, 02:25 PM
ogre's Avatar
i used a 03 mustang hydroboost/mc with stock 58 chevy truck pedal
i ran a couple years with the reservoir underfloor, added the remote reservoir after i broke a banjo fitting
remote reservoir is off a first gen nissan quest
ID:	441703   Click image for larger version
Old 03-30-2019, 09:19 AM
staleg's Avatar
Last journal entry: Hand brake
Here's mine. Brake and clutch. Home made and made so I can adjust pedal ratio and pedal resting-position
Driven with it from 2013. works fine.
Some of the material thickness is probably a bit overkill, but better safe than sorry, and it is very sturdy.
Old 03-30-2019, 05:11 PM
remote xxgb is off a first gen nissa "c n quest
That is what I am fitting parts for currently behind the cab. Simple and puts the thing in a easy to fill area.
Looks great.
I hate banjo fittings. They rely upon perfect machined surfaces and often that is not the case.
Old 03-30-2019, 05:12 PM
Awesome setup. Going to borrow your adjustable pedal idea.
You can never go overkill with brakes or steering.
The Following User Says Thank You to cerial For This Useful Post:
staleg (04-24-2019)
Old 03-31-2019, 08:27 AM
Old(s) Fart
Last wiki edit: Wheelbase database
You know you can just buy these from Wilwood, right? $100 from Summit, Speedway, etc.
64 Dash re-cover questions. rohrt Interior 29 12-05-2015 11:42 PM
No brakes on my Grand Prix billonwheels Suspension - Brakes - Steering 5 05-06-2015 09:01 PM
Ford Expedition Brakes Augusto Suspension - Brakes - Steering 33 03-05-2012 06:37 AM
Manual disc brakes galaxieguy3 Suspension - Brakes - Steering 6 07-21-2009 07:49 PM
Need Help With My Brakes S10 Racer Suspension - Brakes - Steering 4 01-18-2009 03:00 PM
