Best Cam for Peanut Heads on 454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2017, 11:22 AM
Hello all you car gurus. I keep dreaming of building a Gen V 454 with a little pep above stock. I want make as much streetable HP as possible without spending a fortune. First, I'm looking to put in some pistons with 22 cc domes to try to get the compression ratio up to about 9.4:1. With the peanut heads (10114156) having 118 cc combustion chambers and with some pistons like the ones I mentioned, I should get close to 9.4:1. Now, what would be the most streetable cam to go with this combination to produce good power and still use the stock converter, pushrods, and rocker arms? Heck, if I could, I'd use the stock springs too but I don't expect to be able to do that. I've read that if the lift of the cam is over .500 that the stock springs are useless. I've been doing a lot of reading on cams since TechInspector1 responded to another thread and have decided that the cam I thought would be good is not a good choice. I don't want to invest in roller lifters or rockers. I just want an engine that sounds good with a little rumpity rump at idle and can make power from idle to around 5000 rpm. And from what I've been reading, the heads I have are only good to about 4000 to 4500 RPM.
So, any ideas as to the best of all worlds "go between" cam for such a configuration?
Thanks in advance to any responders.
Spicer411
Old 02-16-2017, 01:42 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Well, all I can tell you is what I would use if it were my motor.
Howards CL120235-12 hydraulic roller cam and roller lifters kit.
Howards 98636-K32 spring, retainer and lock kit.
Howards 94580 solid aluminum thrust button. Trim to fit and allow 0.005" to 0.008" thrust play.
Cut a piece of flat steel, 1/8" thickness (0.125") to fit inside the front cover and tack weld it in. This will allow a solid wall for the thrust button to push against without bowing out the front of the thin sheet metal cover. Alternately, use a cast aluminum front cover.
This cam will exhibit strong low end and mid-range power and torque, smooth idle and good gas mileage on premium pump gas. If you build a good, tight squish/quench into the motor, it might do it on 87 octane pump gas without detonating.
The lopey idle you're lookin' for won't work with your low static compression ratio, unless you use one of those Fosdick CompCams Thumpr cams......
https://www.summitracing.com/parts/c...make/chevrolet
But you're giving away power to get the sound....If you're OK with that, go for it. Use the CompCams roller lifters and thrust button.
Whatever you do, don't try to use a flat tappet cam in a big block Chevy with aftermarket springs.
And for those of you who don't know Fosdick, he was a detective on the Dick Tracy comic strips who was constantly screwin' up. So, anything that's screwed up, to me, is Fosdick.
Old 02-18-2017, 07:32 AM
vinniekq2's Avatar
To do a "proper" cam swap you will be spending a little cash. The peanut heads need help,,,
You need a performer rpm intake and a well built Q-jet. You need small diameter long tube headers and a very free flowing exhaust system.(Like dual 3 with cross over.) I would clone the cam Richard chose but with 5 more duration. You will use the complete cam kit.The engine may not have a lumpy exhaust sound but wfo will sound amazing!
If you are using a factory F.I. system tell us about that first as that changes the problem.
Old 02-18-2017, 11:25 AM
camarodriver67
If you absolutely have to use a set of peanut port heads I would use a Howards roller camshaft like this one. It probably is the largest that you can use along with a Edelbrock Performer RPM intake manifold and either a Quadrajet like Vinnie suggested or Holley 850 DP Street https://www.holley.com/products/fuel...arts/0-82851SA or a Holley 950 HP Street https://www.holley.com/products/fuel...arts/0-82951SA
Old 02-19-2017, 10:15 AM
14081052 heads
Can the heads below be mated to the Gen V 454 engine?
Details for 14081052
Casting Number14081052Added to Site2010-12-25 18:03:33 (2248 days ago)ManufacturerChevroletCategoryCylinder HeadsTypeBig Block V8Date1985-1987Notesoval port, open chamber, 366 tall deck, 427 tall deck, 454 Truck, Marked "HiPerf"
Old 02-19-2017, 10:23 AM
vinniekq2's Avatar
you can get around 400 hp from the peanut heads. What are you looking for?
Old 02-19-2017, 08:13 PM
Well, I can't spend $665 just for a cam and lifters. I found some oval port heads online and thought I might be better off with them. I have a pickup truck that I want put this 454 in. I've read a thousand articles and forums concerning putting older heads on the Gen V block. Many talk like it can be done without trouble and others claim it's almost impossible to make it work without internal coolant leaks. I want something that'll rev and continue to make power up to around 5500 RPM. From what I've been reading, the heads I have are only good to about 4000 - 4200 RPM and then they fall flat on their faces. What do you think about this particular build using peanut heads?
Cheap Big-Block Chevy Engine Build - Hot Rod Network
Old 02-19-2017, 08:36 PM
Wiki Edits: 326
After your BBC has eaten a couple of flat tappet cams, you'll wish that you had used a roller hydraulic from the beginning. You have been warned.
Old 02-19-2017, 09:03 PM
vinniekq2's Avatar
reiterate what I posted?
The engine you found is what I said you can have. I would listen to Richard about a roller on a rat. Butt;if you want to save nothing then buy a flat tappet hydraulic cam,,,
how much extra over a couple years will it cost for additives that the roller doesn't need? Same price in the long run but you get to use a cheap lower performing cam!
Old 03-06-2017, 03:34 PM
6426yy's Avatar
Peanut ports can be made to perform but our results will NOT be as good as these. https://youtu.be/DjIVRz_w9bw
454, cam choice, gen v
building a budget 454 with peanut heads darkostoj Engine 13 10-12-2013 09:27 AM
How do I get 500 Hp out of a 454 with peanut port heads? ucarlg Engine 62 10-06-2013 05:35 PM
454 peanut heads topever Engine 1 11-11-2010 01:14 PM
cheap 454 with peanut heads Haulin327 Engine 6 05-27-2006 11:06 PM
Budget 454 rebuild w/peanut heads Rhansen Engine 3 03-22-2005 07:06 PM
