Hot Rod Forum : Hotrodders Bulletin Board (https://www.hotrodders.com/forum/)
-   Hotrodding Basics (https://www.hotrodders.com/forum/hotrodding-basics/)
-   -   Best coating for new exhaust manifolds (https://www.hotrodders.com/forum/best-coating-new-exhaust-manifolds-521223.html)
ml69 05-19-2019 08:30 PM
1 Attachment(s)
Guys,
I’m finishing up the assembly of a pontiac 489 for my 70 GTO. I purchased sone new RA exhaust manifolds and I want to coat them for some protection so they don’t rust. I’m guessing I have three options. I can use some Calyx manifold dressing, I can paint them with exhaust paint or I can have them ceramic coated. Which do you think is the best option based on factory-ish appearance and durability? I attached a pic of the manifold. Thanks for your input.
Mike
OneMoreTime 05-19-2019 08:34 PM
Ceramic hands down
Sam
ericnova72 05-19-2019 08:53 PM
Calyx if factory appearance is a prime concern....ceramic if long term durability of the finish is desired. Ceramic doesn't look factory though.
Calyx you'll have to re-do every so often to maintain it.
Eastwood has a stainless paint that holds up decent....any other paint I've not seen last for more than a year or two.
lmsport 05-20-2019 08:13 AM
If you want to do it once, get it coated by Jet Hot. Theirs is the only stuff I have never seen come off. They have a finish that approximates cast iron.
astroracer 05-22-2019 08:36 AM
X2 on the JetHot
Mark
PHWOARchild 05-23-2019 01:21 PM
I used POR15 manifold paint on my ram horns 10,000 miles ago and they are still holding up. I sprayed them, put them in the oven @ 400 for 2 hours. Although a ceramic coating may be a little better for you.
fat tire 05-23-2019 07:18 PM
check out cerakote. they have many colors and you can do it yourself
