Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best Front End Alignment Tool for the Home Mechanic?
Old 12-18-2018, 07:09 AM
55 Tony's Avatar
55 Tony 55 Tony is offline
Without proper turntables under the tires that setup will have to come off and on again after every adjustment so you can roll the car back and forth a few times. I used a cheap (around $19) tool to do the castor, a plain level cut to the length of the wheel to do the camber, and I am getting or making toe plates ... for the toe.
